The quick part:
If an input port on a multi-switch is not plugged into an LNB (say, the 13v one is disconnected, and the 18v is connected to an LNB) - will this cause physical damage to the multi-switch, or will it operate normally?
The extra info:
My scenario: I have a corotor with a C-band LNB and a Ku-band LNB.. and they are single output, and operate at 15-24v. I want to be able to have multiple receivers hooked up to them but they (obviously) don't do polarity voltage switching.. so I would only use the 18v ports on my multi-switch which would essentially make it a 22Khz switch between bands.
There are some obvious polarity issues that will arise, but I'm not really intending to use multiple receivers AT ONCE, just don't want to keep plugging and unplugging crap when I want to use a different box.
If this isn't possible - could I just take an extra dummy LNB I have laying around and hook up to the unused inputs? I really want to make use of the 8 ports on the free switch I was given
[read: How many tuner cards can I hook up at once
P.S. - other than this question, the tutorial on multi-switches in this forum was awesome! Many thanks to the author(s)!
The extra info:
