2x1 switch-Glorystar
grasshopper1
10
Stexas
Does snyone have a method/procedure to test this switch on GloryStar equipment? AND will a DISH/Echostar 2x1 switch work just as good? How about DirecTV's multiswitches, will they work on Glorystar? I used to do installs for Directv and Dish a few years back. So I have spare switches?
ANy and all help is appreciated.
Thank you
The more commonly used switches on FTA are diseqc and 22khz.
They operate on different principlds.
The DishNetwork SW21 is in a third category.
I don't know of a 100% reliable way to test any of them, other than passing signals and power through them.
Each would require a recever be set up for the particular switch (and I don't know if any Glorystar receiver can operate the SW21).
The general rule of thumb for FTA switches, is to not connect or disconnect them when the receiver is powered on.
I found all the DishNetwork switches handled such situations with 100% reliability. :)
Some FTA switches will; some may not.
For more info on these and multiswitches, and how to apply them, you might give a read of the Switches Simplified thread in the FAQ department.
Thank you
If you have the dual output LNB's the Zinwell or Eagle Aspen 4x4 and the powered 4x8 switch will work. If you only have the single output LNB's then you need a 2x1. The Dish SW21 does not work.
Which LNB
Is ION still ITC on 119W?
