Anyone have an FTA dish up in a mobile home park, what are restrictions, I see alot
of the big direct tv and dishnet dishes with triple lnb.
If you own the trailer you could put up to a 1 meter dish with no issues. The land you rent so there may be some issues if the trailer park owner says you cant do that
But I've seen numerous Slimline and Dish 1000.2 dishes in mobile home parks
They more than likely won't object to an install if you see dishes around. Most landlords would rather you put it on a pole than mount on the roof..so you should be ok.Yes, I rent the space, I want to install geosat 90cm, I want to put a schedule40 steel pipe, so I dont have to drill into the roof. My neighbor has the big direct tv
dish, the one with hd. the geosat does not look much bigger than that. once,
the weather breaks, will put it up, see if i get any complaints. by the way i do own the mobile home, we all do here, no rentals allowed here
is the neighbors dish a pole mount?
since some have pole mounts then there really shouldnt be an issue but check with the trailer park in case there might be some rules as to where its placedsome have dishes on ground
using a pole.
Yeah, gas lines and electrical are major concerns when setting a pole. I'm in a park and my pole is mounted to the side of my trailer sticking about 2' above the roof line. No need to set it in the ground.
I have a 10' x 2" pipe for my primestar 84e. I bought four of the biggest L-brackets I could find and sandwiched the pipe between two of them bolted together. I attached them at the facia and at the bottom on the rim (floor) joist. It is very solid.
My park had no clause stating anything about dishes, and my park manager usually defers to the city or county codes. Our county has no restrictions on dishes less than 36". I'm a little beyond that at 41" wide, but will claim ignorance if anyone gripes.
I am hoping to put in a six footer some day. The county only regulates setting a pole, and the view of the dish from the street (bushes or fence must be in place an extend past 50% of the dishes height). I was going to put it on a non-penitrating mount and consider it temporary. It will be hidden from the street by my enclosed deck. If people gripe, I will break it down and store it.
There are a couple trailer parks near my house and until about a couple years ago they had big C-Band dishes for G5 programming. I remember my buddy's dad had "cable" but it was just the G5 stuff on different channels
Sadly those dishes are gone...I wish I could have got them![]()
Here you go. It's not pretty, but it works well.
