Your G-19 Signal Report is Needed
I'm showing it here in Oregon.
Using a Geosatpro 90cm, a GSL1u on a SG2100 and the Coolsat 6000 with the 0.06 firmware:
Tapping the "Move Fine" West 3 times in the Motor menu strengthens the Horizontal side.
Makes a significant difference quality-wise
12152 H and 11842 H go up from 69% to 72%
12177 V and 12115 V drop from 69% to 66%
It's a matter of 10% Quality on the Geosat meters!
11789 V 28125 - SQ: 69%
11836 V 20765 - SQ: 70%
11842 H 22000 - SQ: 78%
11867 V 22000 - SQ: 71%
11874 H 22000 - SQ: 66%
11936 H 20000 - SQ: 67%
11966 H 22000 - SQ: 68%
12053 V 22000 - SQ: 72%
12060 H 22000 - SQ: 68%
12115 V 22425 - SQ: 69%
12177 V 23000 - SQ: 69%
here in MN they read the same. All nice and strong
If I bump it west or east the quality drops on all TP's across the baord
Submitted by: AcWxRADAR
LOCATION: Omaha, NE (~40 miles NW of the city proper as the crow flies)
RECEIVER: AZBox Premium
ANTENNA: GeosatPro 1.2M
LNBF: Invacom QPH-031
MOTOR: PowerTech DG-380
SWITCH: Chieta HD 4x1 DiSEqC (F = 900-2400 MHz, Insertion loss: 1.5 dB, Isolation: >30dB)
CABLE: ~300 feet of RG11 + ~50 feet of RG6 quad shield.
SATELLITE: 97°W Galaxy 19
LOS: OPEN and CLEAR
11836 V 20765 - SQ: 64%
11842 H 22000 - SQ: 76%
11867 V 22000 - SQ: 67%
11874 H 22000 - SQ: 73%
11936 H 20000 - SQ: 74%
11966 H 22000 - SQ: 72%
12060 H 22000 - SQ: 75%
12115 V 22425 - SQ: 61%
12177 V 23000 - SQ: 63%
I thought it would be informative and interesting if I tested these same TPs using my SuperBuddy meter for comparison. This morning, my skies are overcast and there is light rain, therefore my signal quality readings are different. I have used my AZBox to dial into sat 97°W and then disconnected the AZBox and connected the SuperBuddy at the same end of the cable where the AZBox was plugged in. Here are the results from those tests:
11789 V 28125 - SQ: 89%
11836 V 20765 - SQ: 79%
11842 H 22000 - SQ: 84%
11867 V 22000 - SQ: 86%
11874 H 22000 - SQ: 90%
11936 H 20000 - SQ: 89%
11966 H 22000 - SQ: 91%
12053 V 22000 - SQ: 88%
12060 H 22000 - SQ: 94%
12115 V 22425 - SQ: 80%
12177 V 23000 - SQ: 83%
RADAR
Finally got around to testing the signals.
Using a GeoSat Pro 90 CM dish with Two GeoSat Pro SL2 LNBFs in a GloryStar configuration with a GeoSat Pro DSR-100c receiver, the following are my numbers.
Located NW of St. Louis, MO. :)
11789 V 28125 - SQ: 60%
11836 V 20765 - SQ: 65%
11842 H 22000 (new) - SQ: 55%
11867 V 22000 - SQ: 60%
11874 H 22000 - SQ: 65%
11936 H 20000 - SQ: 60%
11966 H 22000 - SQ: 55%
12053 V 22000 - SQ: 70%
12060 H 22000 - SQ: 70%
12115 V 22425 - SQ: 70%
12177 V 23000 - SQ: 70%
Here's what I get in North Georgia.
11789 V 28125 - SQ:60
11836 V 20765 - SQ:75
11842 H 22000 (new) - SQ:60
11867 V 22000 - SQ:74
11874 H 22000 - SQ:74
11936 H 20000 - SQ:75
11966 H 22000 - SQ:70 (61-75)
12053 V 22000 - SQ:85 (74-90)
12060 H 22000 - SQ:75
12115 V 22425 - SQ:88
12177 V 23000 - SQ:74
Quebec city,Quebec,Canada
4 ft Fortec / Invacom quad / VS Ultra
Current Conditions – Clear skies
11789 V 28125 - SQ: 87%
11836 V 20765 - SQ: 69%
11867 V 22000 - SQ: 63%
11874 H 22000 - SQ: 79%
11936 H 20000 - SQ: 83%
11966 H 22000 - SQ: 75%
12053 V 22000 - SQ: 74%
12060 H 22000 - SQ: 72%
12115 V 22425 - SQ: 57%
12177 V 23000 - SQ: 72%
Cheers you all !!
Sas
Please indicate the size of your dish and your location and report on the frequencies below:
11789 V 28125 - SQ: 63%
11836 V 20765 - SQ: 80%
11842 H 22000 (new) - SQ: 84%
11867 V 22000 - SQ: 29%
11874 H 22000 - SQ: 84%
11936 H 20000 - SQ: 56%
11966 H 22000 - SQ: 18% to 25% varies
12053 V 22000 - SQ: 87%
12060 H 22000 - SQ: 85%
12115 V 22425 - SQ: 36% to 41% varies
12177 V 23000 - SQ: 85%
Thank you for your test results and taking the time to provide valuable assistance for qualifying this new transponder!
Receiver: Coolsat 6100 Private
Dish: motorized GEOsat PRO 90cm / Pansat linear std LNBF
With the dish aim optimized for the new 11842 TP:
This morning I've noticed an improvement on most of the TP's signal quality but still have low levels on the 11867, 11966 & 12115. They have a stable video regardless of low quality signal status.
it sounds like the 11842 TP is messing up others.
I noticed today on the 30" if I peak on 11842 I lose 11867, 11966 & 12115 and 12177 is real low. If I peak on 11966 then 11842 is kinda low. I'm in Minnesota
Whewww! Iceberg, I was starting to think that something was wrong with my setup, thanks for the confirmation.
Do you experience this same issue with a 90cm or larger dish or is the problem amplified with a smaller reflector?
As you can see that Iceberg is getting almost the identicle results as my 90cm, I only have 90cm Ku dishes to test this Ku band with. I hope this helps.
Thanks for your concern :D
on the 90cm/GeosatPro setup I do not see the same issue as I get on the 30"/Coolsat 5000 setup
Right now the 30" is peaked for both now...When peaked either the 12115 batch or 11842 reads 72-73 and the other is 63 (just threshold) or nothing. Right now they all read about 69-70
I'll do some more testing later...right now recording something ;)
I just tested on my other 90cm fixed dish that has a different brand std linear Ku LNBF and it tests much better with more uniform signal qualities throughout the TP's, it may have something to do with the LNBF's so my next experiment will be swapping out the LNBF on the motor dish and test again.
Revised Test Results
I just swapped out the LNBF on my motorized 90cm dish and readjusted the east/west AZ and these are the test results that are much better here in the 93555 area code So Cal
11789 V 28125 - SQ: 82%
11836 V 20765 - SQ: 83%
11842 H 22000 (new) - SQ: 85%
11867 V 22000 - SQ: 73%
11874 H 22000 - SQ: 85%
11936 H 20000 - SQ: 82%
12053 V 22000 - SQ: 86%
12060 H 22000 - SQ: 87%
Using a 6ft prime focus dish, BCS621-2, a Pansat 2500a, cloudy/rainy night (6ºC) here in Baja (Ensenada):
11789 V 28125 - SQ: 83%
11836 V 20765 - SQ: 84%
11842 H 22000 (new) - SQ: 70%
11867 V 22000 - SQ: 70%
11874 H 22000 - SQ: 82%
11936 H 20000 - SQ: 70%
12053 V 22000 - SQ: 60%
12115 V 22425 - SQ: 62%
12177 V 23000 - SQ: 73%
Right now i can't use the 90cm offset nor the 8 and 10 footers (my nephew is asleep in my room where i have those antennas connected to my receivers... LOL).
Cheers
Mike
11789 V 28125 - SQ: 80Q
11836 V 20765 - SQ: 78Q
11842 H 22000 (new) - SQ: 79Q
11867 V 22000 - SQ: 20-30Q
11874 H 22000 - SQ: 83Q
11936 H 20000 - SQ: 10-15Q
11966 H 22000 - SQ: 20-30Q
12053 V 22000 - SQ: 80Q
12060 H 22000 - SQ: 90Q
12115 V 22425 - SQ: 20-30Q
12177 V 23000 - SQ: 83Q
Results using 6' a offset Prodelin dish with secondary Tee-Comm T1500 LNBF rigged for 97°W.
Pansat 9200
Clear sunny 50°F
Upstate New York
Welcome HOME to SatelliteGuys!
