THis thread got me trying to remember what I used to do to find subcarrier, and not all of it was actual audio programming. Several of my favorite subcarriers were actually some APT (a form of FAX transmission of images). There used to be AP, UPI news fax, which would be pictures that you'd see in tomorrow's newspapers, and my favorite of all, was a GOES TAP subcarrier that was on a regular TV sat. This was a retransmission of a variety of weather images from the GOES weather satellites.  They cycled through multiple image types.  Really interesting.
   But relative to finding the subcarriers, there were two types of subcarriers, although they were really all the same.  Many were just sent along with some video channel, and would generally be up above the normal 6.2/6.8 MHz audio.  These were pretty easy to find, just with a regular analog receiver.  The second type, however, most people called FM^2 subcarriers, but actually the other subcarriers and the regular audio associated with the video were really also FM^2 too.  These FM^2 subcarriers were on channels that didn't have any video programming at all, and you could find the subcarriers at any frequency from zero up to 9 MHz or so.  You couldn't use the regular analog receiver to receive these though, because those will only tune down into the 5 MHz range, and no lower, because the video and color info was found down there.
  I'd usually look for these FM^2 subcarriers by going through the channels on my analog receiver.  Eventually you'd see a channel that didn't have video, but had what looked like full quieting video, ie a black or slightly speckled black screen rather than the random static screen.  This showed that there was a carrier on this channel, but no video on the carrier.  When I'd find this, I'd go to my ICOM receiver, which would tune FM in the short wave range of 0-9 MHz, and connect this to the baseband output of the analog receiver.  I'd then spin the dial on the ICOM, looking for audio.  I'd have to scan sats in a couple different bandwidths, because some of the subcarriers were very narrow band, and other ones were quite broadband.
  I'd find lots of things that were interesting.  I actually didn't listen that much, but had most of my fun just finding the subcarriers.
Now, with all the digital transponders out there, I guess I couldn't use the same search method, as some of the wide band digital transponders give similar dark screen quieting appearance, so I'd probably end up trying to check out dozens of transponders that were just digital transponders.
Anyway, the old FM^2 days were fun, but as mentioned above, there is LOTs more to be found now that things have gone digital, however it's also easier for them to encrypt or put it in modes that we can't listen to, so to some extent the stuff you found back then tended to be more interesting.
