lost the 119 signal
putterboy
55
Greetings, I have recently lost the 119 signal, showing all zero's on the signal meter. I'm in zip 01001, hr20 with 2 lines in, no switches. Would possible culprit be a faulty lnb, or possibly change in my LOS ? Dish still seems rock solid and level, pole mount. If the LYNGSAT info page is correct, I'm only losing the sd locals, which I don't watch anyway. Any suggestions appreciated- thanks:confused:
Not only will you lose your locals, but the guide data, also. It comes from the 119 satellite. Are your signal levels good on the other sats? Can you post them? It could be a bad lnb or los. How about a picture from behind the dish? 119 is pretty low in this part of the country.
101 sat=== 93 to 100, 110sat==95 to 97, 99c==82 to 92, 103 ca==72 to 88 ,103cb==57 to 79 --maybe some new tree growth causing change in los?
It looks like your signal levels degrade as you go west, so maybe a realignment will bring back 119.
It comes from 101 on the 5 lnb also.
I've done a little research, and unless Directv has changed something, guide data comes from 119 with a 5 lnb setup, and 101 with the 3 lnb.
DirecTV offering Limited-Edition NFL Remotes again!
Diaglog Norm audio dropouts
