I have a Direct TV Slimline-5 dish on my roof with .jpg pictures attached to this thread.
*Note* When viewing my pictures please ignore the adjacent "Dish Network" satellite dish on the roof with 3 white wires attached to it as it is not in use.
I do not know the exact model of my Slimline-5 dish and weather or not it includes the SWM technology already built into it.
In the photo you can see 2 connected black RG6 coax cables coming from the Slimline-5 LNB.
Each of these connected wires makes their way into the house to different rooms for connecting my current equipment consisting of 2 HD receivers (H21-200 & H23-600). This set-up works fine and was configured by a Direct TV installer.
As you can also see in the picture are the other 2 RG6 coax cables coming out from the Slimline-5 LNB. These 2 wires are capped and dangling right there in the picture.
I ordered a 3rd receiver today, it is the latest DIRECTV Plus DVR receiver.
I also want to put what will be the extra HD receiver in the kid's room where I will have to run a RG6 coax.
What I will want to have connected are (2)HD receivers and (1)HD DVR receiver which will require a total of 4 channels of information.
Here is my question and correct me if I am wrong because I probably am
Do I first need to verify if my Slimline-5 LNB has SWM built in to save myself the expense of a SWM-8, if it is then can I just buy a Direct TV approved splitter and make the necessary connections to one of my two feeds coming down and into the house?
If the Slimline-5 LNB does not have SWM built in then will I need the SWM-8?
In order to verify if the dish has SWM built into it, I am thinking of waiting for my DIRECTV Plus DVR receiver to be delivered, once I get it I can trade places with one of my existing HD receivers. I would hook up the RG6 coax cable to the Sat 1 input, leave Sat 2 input empty. Then proceed to record 2 channels at once on the new HD DVR.
If I am able to record 2 channels at once with my DVR would this verify that I am getting 2 channels of information through one single physical RG6 coax feed? I would also run upstairs and check to see if I lost signal in the other room with a connected HD receiver undisturbed.
If I can not record 2 channels at once with the HD DVR then I assume that the LNB is does not have SWM built in. I will then have to purchase the SWM-8 kit and install it, but then again I will have some questions regarding that as well because the wiring schematics show 4 RG6 cables coming into it and I only have the 2 RG6 cables coming down from the roof and I'm not about to go up there just yet.
One thing at a time lets see if I am onto something here first since it's fairly apparent that I don't know sh*t about dish technologies!
