Transponder Problems on AMC-3
billyboy_1
314
33
Southeast Missouri
Ok I have a strange problem & have been waiting to post until I checked it out all the way. I have three of the Openbox S-9 machines. I am using them on AMc-3 C-Band for the rtv channels. Only one of them will pull all of the T/P's..ie the 3800's and the 4080's getting all the channels that are active. The other two only get the stronger ones at 4080. I can hook up any of the receivers at any of the lines coming from the switch which is a DP-34 and no matter where they are connected the same problems happens. The signal strength and quality are great on all channels on the one rec but are not enough to pop channels on the weaker (3800) on the other two. I have peaked the antenna out as far as possible without have a highend meter. Sure would like to know that answer to my strange problem. How could the one rec do what the other two won't ?:confused:
Might give up a few more details, like how big is the dish, and your wiring details. I think a DP-34 is a dish network switch, might work perfectly fine for what you're doing, but I'll let the switch gurus sort that out for you! Seems that if one receiver of the three identical ones receive everything , they all should.
try bypassing the switch temporarily....test all 3 receivers out again....do you still get the same problem when your connected directly to the lnb without the switch??
I really don't think he should be using a DISH PRO switch. Instead should be using a disec switch. Have a feeling that could be his problem.
Actually if he is running 3 receivers a diseqc will do no good.
If the LNB is bandstacked (there are bandstacked C-Band LNB's) he can use the DP34. Folks have used them before here with old Superdish LNB's or these C-Band LNB's.
Clean simple install but the one issue is they do require alot of power to work properly.
So he needs to find out if the DP34 is the right switch or if he has enough power to run it. Is that a correct summation of what you just said?
If the LNB isnt the right type I dont think the DP34 works properly
But he says one receiver works fine but the other 2 don't so it could be a myriad of things.
If he is only running that dish in his setup I personally would change that switch out. I've used DP34's on FTA setups and while easy setup they can have issues
The dish is an 11 footer with a brand new geo-c2. The one rec that gets everything is running 86% signal and 76% Q. I have bypassed the switch and still have same problem. The only reason I'm using the dishnet switch is becauce I don't have a diseqc that will allow more than one rec output. I have not had any issues with the switch. It seems that the one rec has a lower threshold. It may be newer or older as far as the chipset or tuner possibly and thats just a guess. I had an Azbox at first and it would not pull the weaker T/P's so I got the openbox and one of three of them gets all the T/P's. I know this is a weird problem but thats how my luck goes. I have tried many different things such as bypassing the switch, moving the rec's around to the different locations in the house but it does not matter which line i try, the same problems exists.
I'd swap it out for a cheap 3x4 multiswitch. Thats what I use on my setups
something like this
they work just fine and use way less drawing power than the DP34 switch
Ok Ice..I bought that switch...Now to hook it up, I am running another 33 inch KU band antenna with a invacom lnb, What would the connections be? I see that the Zinwell has 18 volt, ant and 13 volt connections. i am thinking that the middle conection ( ant) is an off the air.
If you are using the 3x4 switch with the GEOSATpro C2, no switch setting are necessary as this is a voltage controlled switch. Just make sure your receivers are configured for the default 18vdc = Horizontal and 13vdc = Vertical.
Correct! The 13 and the 18 connect to the dual output LNBF and the middle connection is for optional terrestrial antenna for use with diplexers at the receiver(s).
If you want both the GEOSATpro C2 on the BUD and the 33" KU to be distributed to all three receivers, you will need a 4x4 Multiswitch http://satelliteav.com/p/shop/?ws_pid=654&ws_cat=429 and the KU band LNBF to be a dual output.
Right...I need two different lnb's on two different dishes ran into the switch..and then out to three receivers.
Then you would use the 4x4 multiswitch that satelliteav mentions.
Here is how it would be setup (courtesy of anole)
http://www.satelliteguys.us/fta-mpeg2-faqs/134124-switch-setups-simplified.html#post1344314
attachment.php
I found a Channel Master multiswitch 4x4 out in my shop. It appears to be that same switch.
motor puzzler
