HELP ON HOW TO TRACK MBC FREQUENCIES
newton
5
nigeria
Hello friends, am facing a big problem, trying to tracking MBC frequencies with 180cm (1.8m) dish, with ku-band LNB installed on it.
the frequency am trying to track was 7.0°W Nilesat 11938.00 polarity: Vertical, symbol rate: 27500 and 7.0°W Nilesat 11766 H 27500.
have done all what i no but i couldn't get through plz GURUS help me out.
thks abu
Nilesat at 7W is pretty far east for most of North America. Where are you located? A 1.8m dish is pretty small if you are in North America looking east at the horizon.
get on a bigger dish find some one local that will let you test i have no exp in your part of the world but know that your not to far from the foot so a larger dish and better lnb can get you what you want
FRIENDS LOOK AT THOSE PICTURES...
MY DISH IS MADE OF FIBER AND IT'S 180 CM
I USED KU-BAND LNB BUT SOMEONE TOLD ME THAT THE LNB WONT WORK WITH THE DISH.
PLZ WHAT KIND OF DISH WILL I USE.
From the looks of the LNBFs you have pictured, It appears they are designed for an offset dish. An offset LNB will not work to well on a Prime Focus dish such as what you have pictured. There are Ku band LNBFs that are specially designed for use on a Prime Focus dish. This would get you the much more stable results than what you were trying.
On a different forum this one was mentioned: Strong Universal Prime Focus LNBF, (SRT L708)
Invacom makes a pretty good Prime Focus LNB, but it requires a separate C120 flange: Invacom SNF-031 'C120' 0.3dB Prime Focus LNB
If it was my setup, I would go with the best LNBF that I could afford.
What you pick depends largely on what your budget is.
Good luck.
You have a Prime focus dish, but are using a LNBF meant for an Offset dish. Your LNBF is only seeing a small percentage of the dish. You need a LNBF designed for a Prime Focus. Invacom feedhorn with a good lnb maybe?
Ku band feedhorns from the Satellite Superstore UK. Prime and offset feedhorns. Low prices. Big discounts
The Invacom feedhorn has a 23mm neck and a C120 flange It is made of
aluminium and has scalar rings. It is designed for prime focus dishes. The rings are adjustable on a screw thread
Adjustable F/D 0.32-0.43
This side of the pond, I know www.satelliteav.com has a Prime focus Ku LNBF.
Thought the Internet went by by, nope, ya just beat me at posting.
Those are circular frequencies so the LNB has to support it
You enter then as vertical or horizontal. The rule I remember is RV
Right polarity-vertical
Left polarity-horizontal
RTN and Tuff Signal
Atlantic satellites and/or low-band Ku in the north
