Hey guys, I am having some problems receiving TuVes HD on Telstar 12
@15W.
MY details:
H/W: 76cm Winegard Ku offset dish
+ TechSAT TRACKER II+ LNB(0.2dB)/Smart Titanium Unv LNB (0.1dB)
+ Openbox S9 HD (latest FW: 11-4-4)
[swapping LNBs had practically no effect on results below, nor did changing Firmware on Openbox]
I am receiving most channels listed on LyngSat for Telstar 12 except for problems with 2 transponders (25/26) beaming TuVes HD signals:
11860 H (I managed get 6 channels 'unscrambled' out of 38?)
tp 25 TuVes HD DVB-S2
MPEG-4
Betacrypt 45000-?
8PSK
(Sig-Q ~ 5-75%)
11920 H (99% channels scrambled, except for blingblingmusic.tv)
tp 26 TuVes HD DVB-S2
MPEG-4
Betacrypt 45000-?
8PSK
(Sig-Q ~ 5-25+%)
I'm not sure if I am lacking signal strength/Q in order to maintain a decodable
signal for the very high symbol rates (45K+) or simply it is my receiver that is
unable to keep up? I noticed when I shutdown my receiver and reboot a short time after the channels come in fine for a few minutes and then quickly degrade until I can no longer watch and the signal meter goes erratic (ie. signal loss?).
[I have a hunch the Openbox might have a problem with HI-SR rates as it maxes out @45000]
This TP below however is very stable (yet all channels are scrambled)
11842 V
tp 33 TuVes HD DVB-S2
MPEG-4
Betacrypt 20000-? (symbol rate is less than 1/2 that of both other TPs)
8PSK
(Sig-Q ~ 65-70+%)
Also I get NO trace of a signal for the TP below:
12167 H
tp 30 TDH
DVB-S2 45000-?
QPSK
Also noticed that my Openbox S9 HD has some problems with the 'blindscan'
as it was unable to detect these bottom frequencies:
11709/V/3195 0308 0256 MSNBC U.S. (Sig-Q ~ 50-65%)
11711/V/2800 0308 0256 TANDBERG 2 (Sig-Q ~ 40-60%)
I had to manually add them in my TP list.
(The BEEPER & BER config options also seem not to work)
So in closing, I would really appreciate if anyone on this board could verify whether this is a TuVes HD signal (or Openbox S9 hardware) problem.
Thanks!
Jay
ps.: I am getting an additonal channel NOT listed on LyngSat: Tandberg CH2 from Israel. This seems to be the weakest channel I can reliably receive:
Telstar 12 at 15.0°W - LyngSat
TuVes HD on Telstar 12 at 15.0°W - LyngSat
@15W.
MY details:
MPEG-4
Betacrypt 45000-?
8PSK
(Sig-Q ~ 5-75%)
MPEG-4
Betacrypt 45000-?
8PSK
(Sig-Q ~ 5-25+%)
11842 V
MPEG-4
8PSK
(Sig-Q ~ 65-70+%)
12167 H
tp 30 TDH
DVB-S2 45000-?
QPSK
Thanks!
Jay
