Installation question
Cosmokramer11
223
Queens
Hello, ever since getting into KU I want to go bigger and get a C band dish. The problem is, I live in an apartment building I know they do not care if I put up a C band dish. I noticed that Galaxy-Marketing still has the 6FT WS1870P still for $69. I would like to buy that dish and try to hook it up. I have a flat roof, I was thinking of putting the dish on a NPRM no one would touch it but I would feel better if the dish was hooked onto a pole mount. I have seen bigger C band dishes that was installed via a wall pole mount I just don't have any pictures to show. I do have this picture of a C band dish installed via cinder blocks. What I am asking is how would I do the same install? Or could I some how install via a strong pole mount? Thanks
Here's a link to a company that sells different type mounts which might give you and ideal of how to install the dish. Just go to C-band Equipment under products and then go the section on Dish Mounts. Also depending on the type of weather you have it might be a determining factor on how you install it. None of the mounts are going to be as cheap as a single pole mount in the yard.
Welcome to orbitcommunicatiopns.com, Online retailers of Dish Network Systems and the home of HDTV and C-Band products
http://www.skyvision.com/pages/parts3.html - has some.
I think a NPRM is the way to go. That also make it somewhat portable if it needs to be moved in the future. I have 2 NPRMs on the ground with several flat concrete blocks under them and blocks in place on the tops.
The dish in that photo needs a larger footprint for proper support assuming it's not in the ground. Those blocks are barely enough to balance it. Bring along some wind and it's history.
Skyvision Satellite Equipment - has some.
Thank I will check those out. Next time I am near the OTB they had 4 C band dishes on wall pole mounts. Hopefully they are still there even though they went out of business
playing whit my new 10 ft
Need Skew Control Option for Football Season
