What type/brand antenna are you using?i can pickup wmc-tv at 80% but i cannot pickup wreg or wlmt. anything i can do to get those in? antenna is about 25 foot up in the air and no clue what name it is. here is my tv fool TV Fool
i really don't know let me see if i can take a picWhat type/brand antenna are you using?
ok. i do get the others on a good day. i know its an old antenna and has seen its daysBottom line is you need a new antenna as from the picture that doesn't have any UHF section on it and that's why your only getting a VHF channel WMC-TV as the other two our in the UHF area. It may have had one in the past but not now!
i thought the tree may be a problem too. thanks for your help!From the picture it sure looks like the tree may not be helping things either. I'm sure you would like to get a picture all the time and not just some good days so like you said the antenna has most like seen it's days. But like I also mentioned that you could just attach a UHF antenna below the other one and joint them and maybe save some money.
i got those channels in for awhile last night but gone again.As Sergei mentioned earlier, you will need a full band antenna to get the desired channels. That is likely much more of an issue than the tree.
okIf you decide on getting a new antenna you might think about moving it to another location and get away from the tree.
Those missing channels are just too weak at your current antenna location.
It may be a dead spot for those channels, try moving the antenna around on your roof.
That failing, get a better antenna.
