Ok, here are the new additions to the family. I was able to listen to some Klipsch Reference, and got some friendly advice from teachsac. I started figuring, why not enjoy them now, why wait for the house build
Will get the surrounds at a later date.
My two fronts:
Klipsch RB-81 II
SPECIFICATIONS
My center:
Klipsch RC-62 II
SPECIFICATIONS
My rears (to be ordered when the room is constructed):
Klipsch RC-62 II
SPECIFICATIONS
I stuck with bookshelfs, but they do have 8" woofers
My two fronts:
Klipsch RB-81 II
SPECIFICATIONS
- BUILT FROM: 2010
- DEPTH: 12.3" (31.2cm) with grille
- ENCLOSURE TYPE: Bass-reflex via front-firing port
- FINISHES: Black Ash & Cherry woodgrain vinyl
- FREQUENCY RESPONSE: 44Hz-24KHz ± 3dB
- HEIGHT: 19" (48.4cm)
- HIGH FREQUENCY CROSSOVER: 1400Hz
- HIGH FREQUENCY DRIVER: 1" (2.54cm) Titanium diaphragm compression driver mated to 90° x 60° square Tractrix® Horn
- INPUTS: Dual binding posts / bi-wire / bi-amp
- LOW FREQUENCY DRIVER: 8" (20.3cm) Cerametallic cone woofer
- MOUNTING: Dual bottom mount 1/4"-20 threaded inserts
- NOMINAL IMPEDANCE: 8 ohms compatible
- POWER HANDLING: 150W RMS / 600W Peak
- SENSITIVITY: 97dB @ 2.83V / 1m
- WEIGHT: 27.5lbs (12.5kg)
- WIDTH: 9.3" (23.5cm)
My center:
Klipsch RC-62 II
SPECIFICATIONS
- BUILT FROM: 2010
- DEPTH: 12.8" (32.4cm) with grille
- ENCLOSURE TYPE: Bass-reflex via dual front-firing ports
- FREQUENCY RESPONSE: 57Hz-24KHz ± 3dB
- HEIGHT: 8" (20.3cm)
- HIGH FREQUENCY CROSSOVER: 1500Hz
- INPUTS: Single binding posts
- LOW FREQUENCY DRIVER: Dual 6.5" (16.5cm) Cerametallic cone woofers
- MOUNTING: Uptilt and Downtilt feet
- SENSITIVITY: 98dB @ 2.83V / 1m
- WEIGHT: 30.4lbs (13.8kg)
- WIDTH: 23.5" (59.7cm)
Klipsch RC-62 II
SPECIFICATIONS
- BUILT FROM: 2010
- DEPTH: 9.2" (23.4cm)
- ENCLOSURE TYPE: Bass-reflex via quad side-firing ports
- FINISH: Matte Black vinyl
- FREQUENCY RESPONSE: 50Hz-24KHz ± 3dB
- HEIGHT: 15" (38.1cm)
- HIGH FREQUENCY CROSSOVER: 1300Hz
- HIGH FREQUENCY DRIVER: Dual 1" (2.54cm) Titanium diaphragm compression drivers mated to 90° x 60° square Tractrix® Horns
- MOUNTING: Keyhole bracket and quad 1/4"-20 threaded inserts
- NOMINAL IMPEDANCE: 8 Ohms compatible
- WEIGHT: 22.7lbs (10.3kg)
- WIDTH: 16.3" (41.5cm)
![IMG_0356[1].JPG IMG_0356[1].JPG](https://cdn.satelliteguys.us/xen/data/attachments/55/55668-d96f64e796b9a03ef6a47e30a5e59a5d.jpg?hash=2W9k55a5oD)
