Might be difficult to do with no buttons...... Some way to lock a "factory reboot" into memory that would cause a boot from USB which would restore the latest working firmware (.abs file) from a usb stick.
Might be possible to have the boot sequence check the usb for the boot file and if that USB stick is not there continue, but if it was --- ie, HardRestore.abs --- grab that file to boot and then let you update from another usb or from the satellite. Have only that file on the well marked USB or you might pop-a-rot-zee -- your brain!
:rant:
