ok ive tried everything i can think of been at it all day after noon. Im aiming for my true south sat 91*w . My bsc621 lnb is sitting with the 0 on the left side and my switch box is at the 4 oclock position. Also my focal depth is set correctly. My pole is plum just so you know my location is 37.74* latitude, long. -90.40*. I am using one of those angle finders from the hardware store (the yellow one). Starting at 0 on the gauge i set my polar axis to 37.7 and my declination down 5.2 degrees to 32.5. Im having alot of problems figuring out if i did it right i have tried several angles. If someone could give the correct angles or something that would be good i have tried and tried to figure them out and none seem to work. Only thing i think might be against me is i have a power line running next to my dish and a transformer near my dish. My GeosatPro MicroHD shows signal level of 45% but 0% quality. So i take it my lnb is working but i just dont have signal. Is my problem the transformer and power lines or am i doing something wrong?
