Hi Bro.RCN is gone for good. Not even marginal signal. Nada, zero. Have you had a chance to see it today?
Around 130 FTA and the rest scrambled. But the scrambled chs are good to tune up the antenna. My dish has two LNBs mounted one aside the other, circular and linear. I also has a 36 positioner and got almost everything from 24W to 127W. ( had to modify the limits)
By the way, MY Gente was gone two alsmot one month ago and today is back.
RCN (40.5 W) & Caracol (58.0W)sometimes are Open sometimes are encrypted.
Last weekend I saw 20% of signal of RCN at 40.5 so I am sure that this is still there but I need to adjust my antenna. The same thing with "Telecafe"..
My Gente Tv is Up there i am watching every day (too much Vallenato.
I am strongly thinking to work in the Proyect to replace the design of the dielectric plate(to "T" or "arrow form" some testers in south america reports good things) and / or use one "despolarizador Turbinado" to gain more signal quality. I dont know If anybody on this forum Have tried before. So Far, I have taken off the Cover plastic on the Top of my LNB because I have noted to gain few points of quality in some Tp's..Example QM, AM sports, Argetninisma channels are viewable after remove the tap. With the Tap these channels are viewable but pixelated so my conclusion is that The Cover is Blocking few points of signal.
One Question You are mentioned that you are Using 2 LNB (circular & linear) with Motor..What LNB you are Using in the center of the focal Point, and what is your secondary..Or you are following the "pedragon" project 2 LNB's attached viewing to the center of focal point
