Considering 99W - Smallest Dish Size?
ZandarKoad
Amish Satellite Technician
2,443
92
Nashville, TN
I'm in Nashville, TN. What size dish do I need to bring in 99W reliably? Also, where does one go to get these C-band LNBs? And are the receivers the same for C-band as they are for Ku?
Mr Tony
4,027
17,370
Mankato, MN
best option? 10 foot or larger
reliably? 6 foot minimum
can you get by on a 4 foot? sure but if it rains or dark clouds you'll lose it right away as you are on the threshold by using a small dish
Since most everything is digital now the same receiver can be used for C-Band or KU. Its all in the menu settings.
As for the C-Band LNB it all depends on $$. I know Brian (Titanium) probably has the LNB you need.
ZandarKoad
2,443
92
Nashville, TN
OKAY, I see that Titanium's LNB is the way to go. Can you feed multiple receivers off a single LNB? I know with Ku, you need an LNB with two outputs, then you can feed those into two 4-way power passing splitters that then feed four 6x8 switches to get 32 IRDs of one dish. How would something like that work with C-band (assuming a stationary C-band dish obviously)?
77TA
562
50
Arkansas
On 99w only If you can live without having livewell network in hd (you will still have it in sd), dodnews and the 2 gdmx syndicated muxes, you can do like I did at my moms. I use a single lnbf with the receiver up front powering the lnbf using a splitter that only passes power on the 1st port. Since everything on 99W other than what I mentioned above is all horizontal any receiver can watch anything that is on.
After scanning in all the channels on the receiver in the front room, I deleted all the vertical channels (those mentioned above) so they could not be selected. Then I told everyone that it had to stay on all the time for anyone to watch tv.
Christopher Cromwell
632
169
Lexington, KY.
You can get a dual output Titanium C-Band LNB, that will let you feed two receivers, that might help cut down on the complexity of splitters and the such. I am a huge fan of Titanium LNB's, definitely the way to go.
Reactions: Titanium
ZandarKoad
2,443
92
Nashville, TN
So Titanium does have a dual output LNB? Then couldn't I hook up a switch with the two lines feeding the 13 and 18 volt ports? Or is the polarity not switched that way with C-band?
ZandarKoad
2,443
92
Nashville, TN
Sadoun has a 6' brand new Prime Focus for $235 shipped. Not bad at all... I don't think that includes any mounting hardware.
632
169
Lexington, KY.
Titanium does sell a dual output C-Band LNB on his website. The polarity is switched automatically for me through the Manhattan receiver I use, with a 4 port switch. You could find the same sized dish for about the same price over at the Skyvision site. I wanted to pick up one myself, but my wife said no on that, so I made do with a 1.2M dish instead for my C-Band. Works good for me. :-)
Reactions: Titanium
wallyhts
Staff member
HERE TO HELP YOU!
3,219
448
Listed but not for sale. "Out of stock" waiting on boat :)
Reactions: Titanium
632
169
Lexington, KY.
By the way, my 1.2M dish with Titanium C-Band LNB is parked at the 99W satellite. I'm still experimenting with getting 2 C-Band satellites with one dish, I hope to get it figured out as soon as the weather improves.
wallyhts
Staff member
HERE TO HELP YOU!
3,219
448
I got one of those a few years ago. It's broke now but was ok for a few years. Hail storms and wind storms killed it. Not sure what model your looking at but I got everything I needed to use it. I got the fixed not the polar mount one.
77TA
562
50
Arkansas
Yes, polarity switches that way on c band just like ku, so it should work.
I have a Sadoun I've used for about a year and a half and love it. Unfortunately I don't think they have any in stock now, but you may want to call and confirm. It works great on 99W.
wallyhts
Staff member
HERE TO HELP YOU!
3,219
448
@wallyhts, oh. :-( Well hopefully ZanderKoad will locate his website and check out all of Titanium's wares, and watch for when the dual output LNB'S are in stock again soon. :)
Not really sure all the details but the slow boat shipment is taking a while.
Reactions: Titanium
Cham
VE4GLS
2,574
1,153
Boonies
My experience tells me not to bother with anything smaller than 8' for C-band, but I am suprised what people are doing with small 48" and 6' dishes these days... The 48" does real well on Ku though for the weak TPs.
Ti, still waiting for that ship too! :)
Sep 14, 2014
10
Nederland, Texas
I was able to get the gdmx muxes with a 1.1 meter dish, and that was with the lnb ducttaped and not even properly lined up, so You should be able to get those.
New Dish
Unimesh dish
