Why do you need such large dishes for Dishnet. An 18" works well here with more than ample signal! That what I used recently when 61.5 was ITC.
You are in Texas so I am guessing no basement (not sure)? Is there a crawlspace you have access to that can bring the wires under the house and then you can bring them up through the floor? If you have a basement I would make a suggestion about having a special window fabricated to replace a basement window similar to what some people up here did when they started installing dryers in their basements.
EDIT: The amateur radio community also has built some pass through panels that are inserted into an open window: http://www.mfjenterprises.com/Product.php?productid=MFJ-4605
You would have to make sure you got one that is suited for your needs. Those are just examples. You would also have to look at security and keeping bugs out as concerns but this is a way to do it with no significant changes to the house.
I like the conduit idea for the cables.
Any building, zoning, HOA type issues to deal with before new neighbors complain?
otard addresses this issueI like the conduit idea for the cables.
how far from the current location are ya moving to? Same town or vicinity?I could get away with putting a 30' tower with a really large OTA ATSC antenna, no worries about that.
Reason I ask is I know we've discussed OTA options for ya at the current spot. One note I know you wanted to get ThisTV from Lake Charles, LA (KPLC). Well FYI they (well the owners Raycom) dropped it in August for the new station "Grit" (I know we've talked about Grit and Escape here)
hey Dee Dee....Joe will help with the dish project we talked about a few days ago...When it turns cooler ( under 80) lets go see
Mrs King ... Of course the wet weather has to stop before we can swim out there..I told him one is his IF he brings the muscle.
If we can get 1 each back to town then its a success..Will call you later when it get drier out there..i stopped by the other day and
the dishes are really out of site now.. but they still belong to us, she says Ok ..waiting on us...good luck moving..
Raycom made the deal but apparently didnt tell the affiliates (from what I've read) but as noted above the current deal with ThisTV needs to expire first. So it could be a little bit before the change is made.OH NO!!!!!!! WTH?????
After I read this I jumped over and did a deep scan for ATSC and I found KPLC 7.x channels and they are still airing ThisTV as of this moment.
Maybe they are planning on dropping it?
yeah you need a VHF specified antenna. I personally have recommended this one to ya a couple timesBut what I really need is a bigger antenna. I have a few mismatched, low budget antennas that are combined into one wire. The VHF antenna my dad gave me was originally sold from Radio Shack as an FM radio antenna.
I love that line. Why? Because you canWhy big dishes? Because I have them. Because I can.
Don't forget to call before you dig in case there are underground utilities. especially power lines. It should be easy to find a number in the place your moving to.
http://www.solidsignal.com/pview.asp?mc=03&p=Y10-7-13&d=Antennacraft-by-RadioShack-Y10713-HighbandBroadband-VHF-TV-Antenna--(Y10713)&c=TV Antennas&sku=716079000994
Its the one I used when I had my house to pick up a VHF station 72 miles away.
Or the little brother MIGHT work but not be as stable
http://www.solidsignal.com/pview.asp?mc=03&p=Y5-7-13&d=Antennacraft-by-RadioShack-Y5713-HighbandBroadband-VHF-Yagi-TV-Antenna-for-Channels-713-(Y5713)&c=TV Antennas&sku=716079000987
If you have the dishes available why not use them. When I had Dish sure the "stock" dish worked fine but I used a 36" dish for 129W (the HD stuff) because as a FTA'er I wanted to max out the meter![]()
oh and Dee ya gotta empty out your PM box. Tried to PM ya but it said "box is full"
GritTv will be replacing ThisTv on KPLC 7.2 when the contract with This expires.
I have a massive oak in my yard (~5 foot in diameter at the trunk) between my dish and some of the weaker towers in the city. I also don't have my antenna oriented towards these weaker signals because I want to make sure I get fox which is in another city and is shaded by some mountains. You get some attenuation from the trees but I wouldn't expect that to kill a good signal. As close as you are to those towers I would guess that you have an antenna issue. I mean a decent sized tree is 10-15db loss right? You are on flat ground. I suspect other factors have to be at play here. I wish that just one place I have an antenna had that flat of a profile. Of course I probably wouldn't live there because I have always been miserable in the flat lands.
It says call for pricing but they have taller towers listed around $1,000 so I'm figuring this would be less than that.
Well worth it to me. The trick would be finding a place where it could tip down.
And rigging some sort of pulley system because this chick ain't climbing 40 feet up in the air, no way, no how!
Biggest antenna, best rotor, no more nonsense..![]()
