Carbon UI Issues Thread
Scott Greczkowski
Welcome HOME!
Staff member
HERE TO HELP YOU!
Cutting Edge
Sep 7, 2003
103,910
29,978
Newington, CT
Having Issues with the new Carbon UI? Please post them here!
Remember DO NOT CALL DISH about issues with your Hopper if you are using this UI!
charlesrshell
SatelliteGuys Crazy
11,298
6,045
O'Fallon, IL
When I select from the Sources menu another Hopper to view a recording, I cannot get the recording to play. I select the recording to view but there is noting to select to start it. Tried selecting the remote play button and nothing happens.
Hall
18,409
3,200
Germantown OH
When viewing a program and you press the "Search" key, it would pre-fill that program name in the search field. Hitting enter would show all instances of that show, including upcoming viewings, episodes on your DVR, etc.
Now it makes it # 0 in the "popular search" list and selecting it just gives you the "Info" screen for that episode. It no longer finds other episodes.
I did, by accident, hit a key (Cancel ?) that actually gives the old behavior but can't remember it now.
lparsons21
9,925
8,073
Herrin, IL 62948
Home Media plays from my Playon server just fine
Edit: noted that when getting out of a video it takes you all the way out to live tv.
Sent from my iPad Pro using Tapatalk
Hall
18,409
3,200
Germantown OH
I have the media server on my Asus router enabled and also have a Plex Media Server running on one of our PCs (both pointing at the same data). I will double-check both of them again
lparsons21
9,925
8,073
Herrin, IL 62948
I noticed that just like the release software, can't play Playon recordings. Difference is it doesn't try and then give an error.
Brandon_m
93
38
Tennessee
Brandon_m
93
38
Tennessee
After about 30 minutes I still have the standby screensaver..... Is that normal or should I be seeing something else?
After hitting download now, mine rebooted and stayed on the standby screen for a couple minutes then went to the downloading screen.
Hall
18,409
3,200
Germantown OH
Is the Joey being used ? Is there a timer that's set off a recording ?
Worst case, just try the Play, Play, Recall steps again. Until it does start, you don't have to worry about interrupting the process. When it does start, walk away.
Ziptied
975
1,143
West coast
When swapping between to paused programs, it now behaves like DTV's "Double Play" feature. Instead of staying paused after swapping, the program automatically resumes. Not a big deal, just different.
jay3860
Jul 31, 2008
13
2
Mid Missouri
I've unplugged all of my Joey's. I have two HWS, it's doing the same thing on both. It will eventually say the receiver is off-duty that software S529 is up to date and update the guide.
Direct enter OTA sub-channels on keypad
How many tailgaters on an account?
