HOPPER3 AND OTA
Has anyone tried recording OTA yet? Can't seem to get it to work.
Sent from my SM-N920V using Tapatalk
I just did a channel scan again but this time I hit the select all button before I saved. Now all my OTA channels are in the guide. They're gradually getting the show titles.
which button is the select button on the new 52 remote thanks
is there a select button on the new hopper 3 remote i will try it out if i can figure which buttom is on the remote that says select.
Right here...follow the big red arrow, Allen:
i tried to do last night when i was creating my favorites list i could not add my over the air channels i tired that select button and it would not work what i am doing wrong.
I cannot save OTA to my favorites list on my Hopper 3, but I can on my 4k Joey.
My bigger problem is the guide will not populate for over the air channels, even the ones that populated with the HWS. I only get one hour of guide data. Is anybody having this problem? It usually populates after one or nightly updates, but I have had it since Sunday and no luck.
in your one of your guide settings you can view your ota channels in the guide.but is seems to me you cannot add them to your favorites list i would like to see this fixed since i get about 35 ota channels from different cites.
Reactions: flody1
Since I have OTA guide data, the only way I am able to record OTA is with a manual record.
I had that issue as well so I did a rescan, saved and voila, could record on OTA. Just wish we could add them to our favorites list.
I don't use favorites list on the H3, but have any of you all tried adding them one at a time from the options menu? I'm not in front of my TV, but you should be able to tune to the OTA channel, hit "Options" on the 52 remote (or the Red button on the 40 remote), then select Add to Favorites on the Options screen (I think its in the upper right of the grid of options). It should prompt you to then select which favorites list to add it to.
Reactions: cummingsje
I don't use favorites list on the H3, but have any of you all tried adding them one at a time from the options menu? I'm not in front of my TV, but you should be able to tune to the OTA channel, hit "Options" on the 52 remote (or the Red button on the 40 remote), then select Add to Favorites on the Options screen (I think its in the upper right of the grid of options. It should prompt you to then select which favorites list to add it to.
Good idea, I'll give it a try when I get home.
