I just got this installed in the spring and am pretty sure I have the 5 LNB setup as I am using a C61k for 4K (104-106). Is there anyplace in the software that will tell me?I should also mention that I believe that Unimas is one of the 119 channels in the traditional Directv English packages so perhaps a LNB swap is in order. There are a few of these such channels. Unimas has a lot of MLS coverage, as it appears you are aware.
Well that explains why I didn't see it ...Unimas 408 is, and always has been, on the 119 satellite so you need the 5 LNB dish to receive it, in HD or SD. Local Unimas (if there is one in Maine) will be on the SL3 dish.
I don't use a SL5 LNB anymore.It's there, I promise you! Is streaming it an option for you?
Yes there is an SL5 reverse LNB available now
I was just confirming why I didn't see the channel.I was addressing the OP. Hopefully s/he writes back with more info...
Yeah my Dish type is SL3 LNB
According to Dish pointer 119 has an 18.8 degree elevation from me.
It looks like I'm getting a combo of Sats around 99-101 which are around 30 degrees.
Thanks for the help guys!
