Local Dish retailer says new Hopper OTA adapter to be released January 24
How many channels can you record at one time with the OTA USB Adapter?
Just one OTA channel at a time with the original adapter, which only had a single OTA tuner. Even though the new adapter is a "dual-tuner" model, it will also, initially, only record one OTA channel at a time. They are supposed to be releasing an new software update in the spring/summer timeframe that will activate the second of the two OTA tuners in the new adapter, after which you'll be able to record two OTA channels at the same time.
Thanks. So this wouldn't be able to really replace the Locals you get from the Satellite then, since if there are 4 shows you want to record on the different local channels at the same time. Bummer...
Correct. Still have to have Sat locals to do that level of watching/recording.
Yeah, it's a trade off that you have to consider. If you are able to drop locals and want to do it, you have to be willing to give up PTAT.
I'm really tempted to order but I'm waiting for dual tuner functionality. I also don't know if the ota recording issues with the hopper 3 have been fixed.
Sent from my Nexus 6P using the SatelliteGuys app!
for one reason you cannot save the channels after u get done scanning the channels in using your antenna i wish someone would bring that feature back
Reactions: pattykay
That is fixed (I think). You no longer have to save them - it auto-saves as you exit the menu/screen.
but the problem is you have to select all the ota channels instead of click on the ones you want and then saving them
could the adding additional ota channels after a full scan has been done be something they address with dual tuner software update?
Reactions: pattykay
Dish and Significantly Viewed Channels
New "Art Work"
