Signal strength change with repack?
  • WELCOME TO THE NEW SERVER!
andy_horton
901
158
Northwest Georgia
I live in the Chattanooga TN market. Most channels are moving. Will this affect the signal strength? Only 1 channel is moving from UHF to VHF, all others being shuffled around in the UHF band. I have an outdoor antenna with a preamp. All local signals are moderate to strong being about 35 miles from most transmitters. Thanks
The movement of WNGH from UHF to low-VHF may require a change in antenna, though.
FCC policy (nor the congressional mandates that drive it) is never going to have even the slightest impact on Physics.
Going from 587MHz to 69MHz (a little over 8.5 times the wavelength) is a huge shift. There will likely be not only significant changes to the antenna itself but also a change in the elevation of the antenna. Changes in elevation sometimes mean a move to a different tower.
Reactions: andy_horton
Plus the OP might now need a honkin' BIG vhf antenna to pick up that channel. A little patch antenna won't do it.
When growing up, rabbit ears worked just fine, as long as you attached a little boy to them.
Hard to watch TV from the side.
Yes, rabbit ear antennas still work, but analog broadcasts were watchable even if snowy. Digital signals aren't, because of the "digital cliff". OP said he's 35 miles away average for his local towers, so rabbit ear antenna may or may not work for him.
Only time will tell. You will have to wait for transition to happen.
Given the sardine packing treatment channels are getting in some areas, you may have to wait for all phases to complete before you can make the call as to whether the signal is "equivalent".
Where I live the market centers are dozens of miles apart so adjacent market interdependence isn't much of an issue. There's either more than 100 miles or the Cascade Mountain Range separating markets.
The big question in my mind is what happens to translators that get caught in the squeeze as translators are pretty important where the topography is interesting. Most of the documentation I've seen has been limited to the primary signals and hasn't talked about translators.
I was, of course, referring to the OP's receive antenna. Obviously the transmit antenna would need to be replaced.
- Trip
Luckily, I am able to receive WTCI Chattanooga PBS which will still be on UHF. WDEF is moving to 8, which I currently get all hi-VHF channels with an indoor flat amplified antenna. All UHF signals come from a UHF 4 bay Channel Master 10 ft up with a preamp. Currently I get all UHF channels reliably, although WDSI is the weakest. It seems to have the lowest power output according to tvfool. Most websites that calculate reception, (estimated I know) say it is out of range. But it is still reliable. WTCI is next lowest. WFLI actually is stronger. I talked with engineers before I put up my antenna and was told Lafayette GA is actually "up" a little higher than most areas around N GA so I should with a good preamp get most if not all Chattanooga stations, except the very low power stations. I could go all out and get an old fashioned VHF/UHF huge lots of elements antenna, but don't need the low powered stations.
Reactions: primestar31
Do we know the dates when this will start?
The final RF channel assignments may not be ironed out until next year. The second and final round of "appeals" (the Second Filing Window") doesn't close until November 2nd and the FCC and the appellants will have to duke it out after that. With significant holidays in them, the last two months of the year are more like one business month at best.
According to the most recent publicly available transition schedule, testing in Phase 1 begins testing in mid-September 2018 and is scheduled to be completed by the end of November 2018.
Transition Schedule
This repack is much different from the previous DTV repack as the channel pool is considerably shallower and there will be quite a few stations and/or subchannels that disappear locally from the airwaves due to an absence of bandwidth.
Transition Schedule
Just a thought on that last sentence..with some channels disappearing, mostly subs, for most major cable tv outfits the signals are brought in via underground fiber. Couldn't the cable companies seize that opportunity to advertise while some channels are disappearing OTA, they will remain on if you subscribe to their cable tv service, seeing as how customers already pay a broadcast tv fee?
How good are you at telling the future? The answer is a year in the future, and involves Federal Regulations.
That depends on how they're set for bandwidth. Some cable operations are struggling for bandwidth just as much or more than the broadcast stations. As they've turned over some of their bandwidth to phone service and security services and an increasing amount to broadband Internet, they're stuffed. And all of this while still slumming along with MPEG2 for their SD and HD video content delivery.
Cable needs to get going on upgrading or they're going to become strictly broadband and that's not particularly efficient use of their bandwidth.
