If it doesn't, I'll just get HDHomeRun even though I've heard that the video artifacts on it are bad.
I want to be able to watch local channels when I'm not home using something like the AirTV or HDHomeRun, I just want to know if the AirTV has DVR support.This item available at Walmart has DVR capabilities. You can use a USB flash drive or EHD to record
Have not tried it personally, but looks promising
You can't stream remotely using an HD Homerun. You would need a Slingbox to do that.
Now please answer my question. Does the AirTV have DVR support?
Oh, it's over LAN, okay. Sorry, I'm just having a bad day today.Your attachment states that you can stream over your LAN. Not outside your local network. You will not be able to watch video from an HD Homerun device away from home without a Slingbox. Period.
And I don't know the answer to your question, but being rude and demanding also won't get you very far on this site. Please be polite.
Do you have a reliable source for such low capacity devices?I have been using it for a few months now, and never had any issues with any drives I threw at it.
Hence my reservations about the utility of a device that you can't find a reasonably fresh drive to use it with.Never have purchased any that small though.
I occasionally see ads for 1TB drives but a lot of them are refurbs or of questionable origin since they perhaps haven't been manufactured for quite a while.
The smallest winchester drive that my local Walmart sells is a 3GB portable. The same goes for Target. Best buy lists two 1TB portable drives on their website but my store doesn't stock them. Costco's smallest is a 3TB portable (their website advertises a 2TB slim). I occasionally see 2TB drives being blown out at Newegg.almart sells reasonably priced HDD's and I'm willing to bet even the least experienced consumer could figure out how to operate it.
Adding a self-powered USB hub to insure sufficient power is probably a good idea for the portable drives adding a little more complexity (rat's nest of wires and wall warts) to the setup.
