Must be a busy download. Have tried a few times with no luck. Maybe needs a better dl site?
Takes me about 3-4 minutes but slow bandwidth here. Installed and playing just fine now. Had a bad USB dongle.
Works great, really like the blindscan.
-C.
I noticed that the file download is very fast if I select to download to open with Winzip instead of selecting to download and save the file.Must be a busy download. Have tried a few times with no luck. Maybe needs a better dl site?
Yes pretty much. Read somewhere not to use a particularly large capacity USB drive, but that was the only one I could get to work (64GB). The 500 and 2GB ones did not, or they were faulty, or weren't recognized by the unit.So my instructions above for loading it worked out ok for you?
Side note: I could see how these reports could be contributed to an online database to create an incredible, accurate real-time, hobbyist generated satellite service list. Anyone?
The service menu reports the number of TV / Radio services found, total scan time and if you wish, saves a transponder and a service log file on an external USB drive! Under 2 minute hardware blindscan on KU 97w! This is great for comparing and sharing. Side note: I could see how these reports could be contributed to an online database to create an incredible, accurate real-time, hobbyist generated satellite service list. Anyone?
Simple XML files, so all we need is a hosted database, display code and moderators. Would be great if the data could also be used for registered users to build custom satellite/transponder/service lists similar to satellites-xml.org.![]()
Sounds like someone would need to write code for a plugin that would send the XML file from the /temp folder in the box to said hosted database every time a blindscan is completed - thus eliminating the need of a USB stick.
