Best Long range UHF outdoor antenna
dfecarter
491
39
Connecticut
Hi am interested in opinions ...
am now considering trying reception with a Winegard HD 7698P , as my Yagi antenna, used with the Kitz 100 pre-amp. , has had a tough time locking in some chs. especially when windy (trees)
however I am concerned about investing in a new antenna with the repack and new DTV format pending?
Is it likely that the frequencies of the Winegard would cover the expected new channel ranges?
Have been using an HDB91X yagi style antenna with a small diopole for 1 VHF - Hi channel in my area
tv fool - TV Fool
The Winegard and all other antennas will work the same as always. Many UHF only antennas are tuned for higher gain at higher frequencies, (above 36) which are going away. So, you might lose a little gain on those type antennas as channels move to lower frequencies. But they'll still work.
As for the Kitztech, I'm VERY partial to the KT-200-coax model. It's the perfect amp for 95% of people out there that need one. Not so much for any other versions.
I have used the Blonder Tongue antenna. It’s fortè is durability.
I believe that you already have the best antenna for the UHF channels from Hartford. Do you want to try another band or another direction? There are stations from New York City and Albany that you might be able to pick up.
Nope, not going to pay almost $400 for any antenna, sorry.
If you're going to drop more than $150, you might as well get a full-spectrum antenna like the Channel Master Masterpiece 100.
The HDB91x is both a blessing and a curse as it has a fairly wide beam (60 degrees). Another consideration is that its gain peaks around channel RF48-52 where the TV band will top out at RF36.
anybody use a
Blonder Tongue BTY-UHF-BB??? for longer range UHF reception
The rated gain (however conservative it may be) is only 10.2dB. You can get much higher gain numbers for a lot less (though you will sacrifice durability and possibly the narrow beamwidth). Examples are the 91XG and its somewhat less powerful knock-off, the HDB91x. Most of the 8-bay antennas have gains in the 10dB range as well.
tv fool - TV Fool
Winegard antennas are simply the best in vhf\uhf combo antennas and unlike Antennas Direc
Winegard makes the best vhf\ uhf combo antennas and unlike the rest are made in the USA.
The 91x is built for max gain at the high uhf frequencies no longer used and like all yagi designs Lacks the beamwidth and capture area so the slightest movement in the wind causes drop outs.
The Channel Master 4228 is a much better choice for deep fringe witg a rotor.
Without a rotor the 4 bay Channel Master is a better choice
It has a much larger capture area and greater gain at the low uhf frequencies.
tv fool - TV Fool
anybody use a
Yes,Blonder Tongue antennas are simply the best built antennas made.
I used their cut channel yagis for master antenna systems and head ends for many years.
You can literally stand on the booms and not bend them and they use a quad driven element so unlike consumer grade antennas they ar
Actually, unlike AD and others,
Actually, Both Blonder Tongue and Channel Master use a DIPOLE as their gain reference instead of the unrepeatable isotropic reference used by AD and others trying to make their gain LOOK higher.
The BT will be over 12Dbi and the 4228 produces nearly 15Dbi peak gain.
