U548
Hey Roland, I know you are exhausted from all this transferring :) but could you try one more thing. Remove your 4 TB and replace it with your 6TB. That would leave you with 8 TB plugged in but both under 7 TB individually. Does the Hopper recognize both and can you make the same transfers. This will prove whether the 7 TB limit is combined or individual. I know the thinking right now is that it's a combined limit but nobody that I have seen has actually proved it.
Also, if that is successful, then try the 6TB with the 4TB for a total of 10TB. That would really bust the myth of the 7TB total cap, if that works. This way, both drives would be over the old individual 2TB cap. :)
  • Love
Reactions: TheKrell and Bobby
Okay, I rebooted and while the Hopper was restarting, I took out the 4TB drive and replaced it with the 6TB drive.
Under DVR it sees one External Drive, the 2TB drive :( Spinning down the 2TB drive, the 6TB drive is not recognized. Spinning down the 6TB, the Hopper message is «You have disconnected a multimedia device from the USB port: ``"»
Spinning up the 6TB drive brings it back. So I'm willing to bet it is a Total Capacity of 7TB for all EHDs. If I had a 1TB drive or better yet a 1.5 TB drive I'd try that.
That is exactly my experience with my 6TB drive and my 1.5TB drive. :( Bug or feature?
  • Sad
Reactions: Foxbat
Okay, I rebooted and while the Hopper was restating, I took out the 4TB drive and replaced it with the 6TB drive.
Thank you Roland. Now we know, for sure it's a 7 TB total.
Interesting. I wonder if it is always the smallest drive that is recognized whenever the cap is exceeded, though. Did you try the 6TB with the 4TB, just to see what would happen? I still say that Dish should reverse the priority of which drive is found, so that the largest drive under the total cap is recognized first, ensuring access to the largest amount of recordings possible. Otherwise, perhaps the labels of "External Hard Drive 1" (for example) should be able to be made sticky to that specific drive, so the priority can be assigned by the user in the event of a conflict (exceeding the total cap).
Reactions: TheKrell
You're all lucky I can't throw anything away;) I found a 1TB Western Digital MyBook that I had hooked up to my ViP 211 before I got a 2TB EHD drive for it. Of course, it needed to be reformatted since the DVR format isn't compatible with the Archive EHD format.
Hmmm, no additional EHD, time to reboot.
Update: After the reboot, I have 3 Media choices, Hopper 3, External Hard Drive 1, and External Hard Drive 2. I'm going to transfer recordings to EHD #2.
I'm going to restrict myself to two or three 2 TB drives at a time.
I can swap them out and keep a catalog on each drive of the contents.
I don't see the need to sacrifice so many programs WHEN (not if ) a drive fails.
I wonder if it's a case of the Absolute Total Amount of disk storage of 8,796,093,022,208 Bytes on this release of the Hopper FW? That works out to 8,192 GB which seems to fit with what I see looking at my 1TB EHD (930 GB formatted) and 6 TB (5,585 GB) added to the internal drive's 1,231 GB available. In my configuration that works out to a total of 7,746 GB.
If I had a 320 GB USB drive available I could see if that showed up since we'd still be under the 8,192 GB limit. If it's 8,000 GB then it wouldn't be seen. Hmmm…
Oh, one last data point. The 1TB drive I found was a USB 2.0 interface, and when I tried moving one of the 4K UHD 2018 Winter Olympics events, it seemed to take much longer (45-50 minutes) than HD events. So I wonder if having a 2.0 device on the Hub reduces the throughput of a USB 3.0 device? More experiments…
When the cap for each drive was still only 2TB, many members here reported that it was actually cheaper to buy a larger hard drive than it was to buy one that met all of Dish's specifications, if you could even find one small enough in the first place. So, I think it is more about giving people the option of using the more common (these days) larger sizes, which may be cheaper to replace when they fail. You do not necessarily have to fill those larger drives, just because you have the capacity available.
Okay, I found a 250 GB Seagate drive and the Hopper doesn't acknowledge it, even if I remove the 1TB EHD. I know there is a minimum size for EHD, but I didn't think it was 250 GB.
edit: Yep, it's too small for a Hopper (320 GB through 7 TB). So much for that expirement.
Reactions: pattykay
I am pretty sure the minimum is 500GB for Wally. If I am remembering correctly, the minimum for Hoppers (any model) is 320GB, and the minimum for ViP receivers is 50GB. Someone can correct me if I am wrong about that.
You are correct. I checked out the Dish EHD specifications:
I guess I owe Bobby a Coke ;)
I'm wondering if I should take the 1TB drive out of the WD MyDesk USB 2.0 enclosure and move it into the Seagate USB 3.0 enclosure. I'm not going to put the 2TB drive into an outdated 2.0 enclosure, though.
Speaking of USB 2.0 vs. USB 3.0, transferring that 4K UHD event back to the 6TB with nothing else connected is taking the same amount of time, so I guess it's just a large amount of data no matter which way you look at it.
Where's that Time Machine when you need to send outdated Tech back to when it came from?
I feel adventurous, and since I extracted the 2TB drive from its USB 3 enclosure so I could put the 1TB drive in it. I have my Sabrent USB 3.0 SATA flat docking station, so tomorrow I'm going to try the 4TB, 2TB, and 1TB drives all at once.
I'm not sure why, but I couldn't get the 1TB + 2TB + 4TB drives to work together. It should have worked with the total storage of 7TB.
  • Sad
Reactions: TheKrell
Time for an upgrade?
New international streaming stations now on dish
