Edision Channel Selection List / EPG
cyberham
6,176
5,231
British Columbia
See attached image. I have EPG info from a different satellite appearing beside channels. How can I remove these? It must be a setting I have wrong.
Sent from my SM-G950W using the SatelliteGuys app!
Reactions: c-spand
The unwanted incorrect EPG data is from 30W which is on a similar frequency:
30 W: 11884 MHz
103W: 11880 MHz
If I could turn off all EPG data then that would fix the problem.
I noticed this early last year already, and turned OFF all satellite EPG data so 30w won't bleed over. To do this: "ENABLE EIT EPG" Should be changed to OFF. Also "Show EIT now/next in infobar" should be OFF. I turned these off, deleted the EPG.dat file, then rebooted, and now the spurious epg is missing.
Turning it OFF, doesn't affect EPG of OTA channels, that still populates just fine.
In TNAP 3.2, I found "Include EIT in http streams" at Setup > System > Customize.
When I disabled and rebooted, this removed EPG data from the Channel Selection list (see image below). So this is a good improvement. But EPG info remains in lower left of screen.
Anybody know where epg.dat is so I can delete? I'm searching now using telnet to the Edision.
Anybody know where epg.dat is so I can delete? I'm searching now using telnet to the Edision.View attachment 148646
My epg.dat was on the root of my external drive I use for recordings.
Sorry, it was here: /media/usb/epg.dat
You can bring up the WebIF screen, and in the lower left, goto: SETTINGS, then click on EPG SETTINGS, and look where it says it is on the right side. "Location epg cache file"
Webif points to /hdd/epg.dat. It seems /hdd has been replaced by /media/usb. But epg.dat is not there. Maybe this is good that I have no epg.dat.
In Webif, I did find the two parameters you mentioned: Enable EIT EPG and Show EIT now/next infobar. I unchecked both and rebooted. No change.
At least the channel area is cleaned up so I will leave it like this.
Reactions: primestar31
OTHER Sat Dish Size Advice
GEOSATpro microHD Database Editting
