Thanks to raydio for setting up a tuner for the ABQ/Santa Fe market!
m.rabbitears.info
OK,Radio, you are missing few stations on RF ch. 8 ATSC 3.0, 10 KCHF "Near Los Alamo", 15 KTEL-CD, 18 KRTN-LD, 20 KYNM-CA, 21 KNMQ-LD and 30 KWPL-LD "From west side near old Coors rd I-40"
The rest of low power stations are from the Sandia Crest Mountain antenna farm.
Congratulations on hooking your reciever to the internet world!![]()
Huh? Where that RF CH. 33 coming from since your tuner showing 100 %, false reading?
See RF39, 40 and 41 at 100%?
That's clear LTE/5G signals. He needs to put one of the new Channel Master LTE/5G filters between the antenna and the tuner. Per my spectrum analyzer, that one kills LTE/5G completely DEAD, NADA, gone!
LTE Filter for Improving TV Antenna Signals | Channel Master (CM-3201)
The Channel Master LTE Filter works with all TV antennas to remove growing LTE signal interference from the broadcast signal your antenna receives.www.channelmaster.com
Between the antenna and the preamp input. That way it knocks the LTE/5G down before it gets amped.Where would it go if someone (like me) were using a preamp?
IF the preamp is built right into the antenna dipole, you can put it after that, and it'll still work, because it passes voltage through to whatever is upstream.
Correct, that's the absolute best way, if you are using an outboard preamp. IF your present preamp has no LTE/5G filter, the Channel Master one may help get stronger and/or additional signals.So it's antenna-->filter-->preamp?
It's only $19 direct from Channel Master with free shipping, why would you pay extra at Amazon? Amazon may just send you and older version, that doesn't go all the way down to 608Mhz, which others have discovered.Cool thanks Mike...cheap...$25.00 on Amazon
