Welcome to XenForo 2.3!
Scott,
I'm not sure how they look on iOS or iPadOS yet, but if it is a pick one over the other, I like the bottom row icons over the old-style top row:
edit: but, now that I see it on my iPad, they do take up a little more vertical space, so I am fine with the previous style.
I like the new style.
Just updated us from PHP 8.2 to PHP 8.3. (Xenforo 8.2 did not properly support 8.3)
You may have got a "Whoops something has gone wrong" message for a moment while I switched us over.
Things look like they are running well on the new PHP version.
Can't hardly see the text for Attach Files and Insert Quote below the text area as shown here:
If you change your style to SatelliteGuys Default No Sticky Navbar it shows correctly.
I am now comparing both styles side by side trying to find the ONE setting that is different between the two.
Well all in all, this upgrade went well thankfully. :)
I think I have everything fixed. Only thing not working is the predictive text when you are typing in the search bar. The author of that plugin hopes to have a fixed version of that Plugin which runs in 2.3 shortly.
Time for me to sign off, as 4:30 comes early then back to work.
Have a good night guys!
I use the dark theme and I've noticed it's really hard to see links in posts, they're barely visible
Need a little help here
Access problem
