TNAP 6.0. Beta-test images
primestar31
15,863
20,612
Beta Omicron Delta III
Load at your own risk, but these are from El Bandido, though are untested.
EDIT. I removed the link, best to not load these until they are ready.
Here's the thread at Legit:
Reactions: norman881
I tried loading the osmio4kplus TNAP6 today into a vacant slot. It loaded, then autorestored and I was able to run it. But I found it wouldn't connect to my network so I restarted and it then hung. To recover, I had to use the emergency power-off method where you power on, press the MENU key repeatedly, then select a different slot to boot from.
Reactions: primestar31
I see you've already let El Bandido know that over at Legit.
I had all of the same issues.
I will monitor progress on TNAP6. But it's not yet ready to install. TNAP 5.1 is great as it is anyway for now.
has anyone here tested TNAP 6.0 a bit further? I just installed it ( build from April 27) and so far it seems stable.
a few observations:
- network interface seems fine - did not play with it but also didn't have to, the box is accessible from my network with Putty so it must be ok
- remote navigation is a bit different (similar to traditional enigma2, unlike TNAP 1-5)
- blind scan seems very slow if there are narrow (low bitrate) transponders. Took 7 min to scan 99W Ku (that's long) but seemed to take normal time (similar to older versions) to scan 34.4W Ku lower band H
- the image selector lists TNAP 5.1 slots as OpenPLI 5.1
- I was not able to lock on KBS World on 123W Ku or on NHK/Muzzak on 101W Ku, but had no problem receiving the K-Love mux on 101W Ku.
- The reception of the French channels on 34.5W Ku was completely normal (tested FranceInfo TV and Radio Transat)
- PBS on 99W was fine but Montana was not found by the one blind scan (but that's not uncommon, right?)
so looks like something is not quite right with the tuning at this time.
Edit: the signal finder just locked on 12000V20000 on 101W, so it is working but it took a long time
In any case it looks like it is a lot more stable than what I was reading in your comments above (about the early January build)
Now, the big question: what new functionality is TNAP 6 bringing to the table?
I've never been a fan of the Enigma-style key mapping -- the arrow keys should just change the channel, what's so {censored} hard to understand about that? If you're lucky, there will be a menu option to "enable neutrino-style zapping" which I think was the default in previous versions of TNAP.
No Video on my Edision OS Mio+ 4k
Edision OS mini 4K image flashing?
