Edision OS Mio+ TNAP 5.1 Service Reports
cyberham
6,605
5,740
British Columbia
Can anybody point me to where the Service Reports are located? These are created each time you run a blind scan and stored. I used to refer to them but I can't find them anymore.
I did find some blind scans from today there. Thanks. Do you know where they are moved to since /tmp sounds temporary?
by default they are not copied and just get erased whenever you restert the box. However if you have a connected usb drive, create a folder in it named "ServiceScan" (make sure the spelling and case is correct), then the service scan logs go in there are are preserved. As far as I know, the blind scan logs (that only list the transponders, but not their content) still go in /tmp and are lost upon restart
of course the logs in /tmp can still be saved to a PC thru the network if you don't have a connected usb drive
Works like a charm! I recall reading this before from el bandido but I can't get into his site now to research. I had to recently reformat my external hard drive so I lost all the Service Reports history. Creating ServiceScan now allows them some place to be transferred to.
... create a folder in it named "ServiceScan" (make sure the spelling and case is correct), then the service scan logs go in there are are preserved...
This worked well for me on TNAP5.1. It's not working on TNAP6. I wonder if this is me or a change in the release.
TNAP 6 for Edision: Yes or No?
Edision Login/Password TNAP6
