Replacing a actuator motor
Houston Rockets
223
113
Dallas Texas
Hello my Venture 36" actuator is starting to turn slow when it has a heavy load on it, I have tried a couple of different IRD's and it is the same..
I am thinking the motor in the actuator is getting weak... My question is how hard is it to replace a Venture 36" actuator motor?
Probably not a bad motor if still running. The jack may need lubing and/or cleaning. One thing to try might be to pull the motor off the jack and see how it runs on its own, vs. when driving the jack.
Reactions: FTA4PA
It has the factory boot on it... it only operates slow when a load in on the actuator, like coming up from lower satellites to the higher ones... it is NOT MAKING any noise and it about 10 year old...To me all signs point to a weak motor..going down hill it moves fine only up hill
Where were you 40 years ago?
