Questionable Line of Site Question
I looked up the direction for my area, and found that it should be facing 185.1 deg. If the closest I can get is about 160 deg (building in the way, couldn't turn any more), would that be within the tolerance range?
You have to be within 1 degree or so on your compass bearing. Buildings are not always a problem, depending upon your elevation setting (you may be able to shoot right over the top of them)
Just thought I would check before writing the idea off. Thanks for your help everyone.
