Questionable Line of Site Question
kevinb961
May 8, 2007
4
I looked up the direction for my area, and found that it should be facing 185.1 deg. If the closest I can get is about 160 deg (building in the way, couldn't turn any more), would that be within the tolerance range?
iwc5893
2,178
The desert of WA, zip code EIEIO
You have to be within 1 degree or so on your compass bearing. Buildings are not always a problem, depending upon your elevation setting (you may be able to shoot right over the top of them)
5 lnb Install
Use 5 lnb dish with old multiswitch?
