Sound Cutting Out
kdjuan
153
23
I have been having touble with my sound cutting out, anyone having trouble with this.
:welcome to SatelliteGuys Juan.
Also we need a little more info on your set-up....like what receiver and tv, stero set-up and such.
i have an onkyo audio receiver, and a hatachi utlravision digital 65' wide screen.
this problem just started after the last national download, my tuner dvd xm and cd sounds fine
Yes, I have had the same type of trouble , not constant , but it's there none the less.
I am using my HR20-700 and get some pixalation and audio drop outs every few minutes or so.
Interestingly enough, it appears on ONLY D* delivered HD channels, my OTA work fine and the SD channels are fine.
This is in mpeg 2 format as I have no mpeg4 to work with yet.
IF I do a reset, the HD channel I am currently on will work flawlessly, until I change a channel, then the next HD channel will pixalate and if I go back to the original HD channel it will also have the problems.
Any suggestions guys ????
I have done reboots and also reset the "Reset Everything" no help.
May have to result in calling D* soon.
kdjuan,
We do need more info on your set up. :)
Sorry to steal the thread, sorta, but it's happening to mine also and we do need to know what your running.
Jimbo
I'm glad mine isn't doing that.I hope it doesn't start either.
You mentioned your A/V rec., is it happening thru the A/V rec., how about when you run just thru the TV without the A/V rec., does it still do it that way ?
Jimbo
Hey Thanks, to everyone for their input, I did some troubleshooting and came to find out that I had a bad OPITCAL CABLE.
Thanks Again
Need Help!
HD Access
