6' or 8' dish on penetrating roof mount
$225.00
two peas in a pod
... I'm going to need the dish, actuator, v-box, and some actuator wire?
Already have a BSC421 LNB.
:D - Ha, ha, ha! - :D
You're as bad as I am!
I've got the Ck-1 and B1stacked C-band LNBf's
. . . and now all -I- need is a dish, mover, vbox, and some wire, too! - :eek:
Maybe Santa will bring us some for Xmas! - :eureka
Oh, and I also have a big wooden telephone pole, but don't intend to mate the BUD with it! - :rolleyes:
From what I've found most C-Band mounts need either 3 1/2 or 4 1/2 O.D. size pipe, so the pipe you have most likely will not work.
Install it correctly the first time and save yourself a lot of headaches down the road.
Just to clarify my previous posting on pipe size, I when out and checked the 7 scraped mounts I have and out of the seven here what I found....I was wrong on the 4 1/2, should have been 4", but the larger size may only apply to people with the Raydex dishes.
1 Winegard 10' dish mounts use 4" OD pipe
1 Zenith 8' dish mount use 4" OD pipe ( same mount as the Winegard )
1 use a 3" OD pipe
4 used 3 1/2 OD pipe
Now both my Raydex dish are using a 4 1/2 inch OD pipe because of the way they mount to the pipe, I could probably go up to a 6" pipe with them, only being limited to the bolts length.
In your case get the dish before getting buying any pipe due to the different mounts and there requirements
Can I move polarotador with out a receiver
Cold weather reminder for all
