722 DVR question
tlturbo
57
Lake Worth, FL
I still have a question about the tuners in a 622/722. I'm concidering upgrading.
I know there are 2 Sat tuners in the receiver and the capablity to receive OTA channels.
On my 921 you can only watch/record 1 HD and 1 SD channel at the same time. If both 622/722 tuners are HD, can you record/watch 2 HD channels at the same time?
What happens when you throw OTA HD channel into the mix? Can you record 2 HD Sat channels AND watch an OTA HD channel at the same time.
How many channels can be recorded at the same time - 2 or 3? On the 921 you couldn't watch an HD channel and record one at the same time. Basically you could only watch/record one HD program (Sat or OTA) at the same time.
What I would love to be able to do is record 2 HD Sat channels and watch an HD OTA channel at the same time.
Please keep any answers non-technical HA HA
As discussed various places within the forums - the 622/722 has 3 independent HD tuners - 2 Sat and 1 OTA.
You can record 3 HD channels at the same time (assuming one is from the OTA Antenna).
...or you can record 2 HD channels and watch a 3rd HD channel (assuming one is OTA).
You can also watch a previously recorded HD show at the same time that you are recording 3 HD channels.
The ViPx22 receivers can only drive one HDTV. The "Dual" output is an SD rendition of the HD channels.
Yes, assuming you have a satisfactory OTA signal.
Three if you have all antenna connections made and working properly.
Soon to be a moot point for you, but the 921 can record 2 HD at once (2 sat, or 1 sat/1 ota), and even let you watch a previously recorded HD at the same time.
The 722 adds the ability to record from all 3, tune MPEG4 channels, NBR, more timers, 3-hour wide guide, optional EHD, etc.
I have recorded 2 ota programs at the same time
along with the 2 sat tuners so I have recored 4 programs at once. Need to see if i can record 3 ota programs ota
with 722
with 722
Wow, you must be some kind of wizard to make the 722 do something it can't do.:rolleyes:
yes I have
with 722
Uhmmmm...no you haven't.
Ok I see how my post was misinterpted my bad.
I have two dvr's (one is a non dish dvr) and I split my OTA and
so yes I can record 2 ota channels at once, no not soley with the 722.
with 722
:rolleyes::rolleyes::rolleyes::rolleyes::rolleyes::rolleyes::rolleyes::rolleyes::rolleyes:
Well, I can record 4 OTA channels and 3 SAT at the same time, of course I have a 622, a 510, 2 TiVo's and a Panasonic Showstopper.
I want to hook up two or three hdtv to vip722.. (I know they will only be able to show the same hd channel) what would be the best way... i tried one hdmi one 50foot componet cable got picture but no sound.. please help,, Thanks
You probably only have the component cable connected and you need to connect a red and white cable for the audio.
Unless you use an HDMI splitter you can feed only 2 TVs with HD, one with the HDMI and one with the Component cable.
you are correct i didnt have the red and white.. Thanks ... would it be better if i got a hdmi splitter to split to three tv???? if so what splitter... I have seen them at monoprice??? Thanks for your help..
Non Reponsive 721
Some more dish questions...
