811 + 508 combo vs just 921 comparison ?
waltinvt
3,439
Vermont
I'm just trying to get a realistic comparison of a 811 / 508 combo to just a 921.
Since the PVR capabilities are obvious and I've had them with my 508, I basically would be just gaining that same feature for HD programs. Same with "record one - watch another" capability since 921 is dual tuner - right ?
Although the 508 was basically bug free, I realize that both the 811 and the 921 have had their share and each have had some software improvments but how do they compare at this point in time ?
I've heard the HD PQ is pretty good on both units but how about SD PQ ? Even though the 811 had improved a lot with upgrades, I still found the SD PQ on the 508 better than the 811. How about the 921?
One thing I'm not clear about is this no HD / SD at the same time business? Does that mean you can't like record an SD while watching HD or visa-versa ?
Will I be able to run a seperate S-Vid & audio out of the 921 to a DVD recorder and have it work while watching a different SD or HD channel?
Bottom line question - if you had a chance to basically do an even swap of a 811 + 508 for a 921, would it be worth it ?
Thanks,
WaltinVt
Recording is not the issue - record 0,1, or 2 of HD, SD, OTA (max of 1 OTA).
You can watch ONE of anything being recorded, or anything already in the box. You can watch using the HD OR SD outputs - but NOT both at once.
Swapping out the 508/811 for a 921 is a no brainer. Same number of tuners, huge HDD, HD recording. Downside is only one output instead of 2. Keep the 508 if that's really important.
