Amazon Echo
wild goose
62
Just got echo is portable or does it have to stay pluged in i want to take outside to pool area
teachsac
Staff member
HERE TO HELP YOU!
Nov 3, 2005
15,476
1,270
Elk Grove, CA
Finally picked one up after my BT speaker mysteriously vanished from work. A little trouble connecting to wifi (not Echo's fault). Once up, everything works great. Sounds terrific. Much better than the old speaker. Play music from phone or Amazon prime.
S~
klang
8,720
5,681
Colorado Springs, CO
They just added the ability for Alexa to control an Insteon Hub. Linked Alexa to my hub, scanned and Alexa found all my Insteon devices. Control is a little slow but it does work.
The Harmony Hub added Insteon Hub control recently too.
Tampa8
Supporting Founder - I'll stand up and say so
18,305
8,156
Tampa/Eastern Ct
We use ours more and more. As someone above posted if they went on sale for $99 again we might buy a second but one is fine.
Reactions: navychop
Foxbat
Addicted to new HW
23,973
19,346
Michiana
So now that Amazon is running commercials for the Echo, has anyone's Echo responded to the "Alexa, read me the news" or "Alexa, how far is Pluto?" commands on the TV?
Tampa8
18,305
8,156
Tampa/Eastern Ct
Yes, talked about on the Amazon customer discussion site. Most of us find it amusing, it mostly happens if Alexa is right near the TV. We use the Echo often, I'm not sure it will be $99 again for awhile.
There is some show my wife watches, could be a soap opera where the person's name is Alexa and the Echo does respond waiting for a command.
rockymtnhigh
Hardly Normal
30,526
1,170
Normal, IL
Amazon introduced the Echo Dot, a much smaller version of the echo, with the same voice commands, but a smaller speaker, and it can be added to your existing echo setup. $89. It has a connector to tie into an external speaker if desired. You can only order if if you have an Echo, and have to order it through the Echo "Amazon order an Echo Dot." Ships in April.
Yeah, I ordered it. I'll put the dot in my bedroom.
Tampa8
18,305
8,156
Tampa/Eastern Ct
Yep, ordered one, Alexa says it will shipped by April 5th....
navychop
Reunite Pangea! Stop overfishing Panthalassa!
63,209
32,013
Northern VA
I only skimmed thru the offer but I "think" some of the processing is done by the Echo. I might consider the dot for the kitchen or LR. Probably not. Need to learn more.
Reactions: TheKrell
Universal remote recommendation?
BT ear buds
