I found this dish a while back and described it in the Adventures in Dish Hunting 2009 thread.
VoomVoom did some research in old satellite magazines, and didn't find the manufacturer.
If anyone can help, that would be appreciated. See below.
Now that I'm convinced I have the go-ahead, here are the pre-harvesting pictures and description:
0 - Perforated 8' (?) dish, on 9' rusty, 3½" pole.
I was there to give it an early PBblaster shot on all the hardware prior to picking it up next weekend.
The dish is really beautiful against the sky.
1 - Base of the pole. The owner didn't want any concrete bashing.
Darned good thing. After last weeks Birdview harvest, including serious concrete destruction, I'm never doing that again!
Figure I can cut the 9' tall pipe off about even with the edge of the dog-run base (4 inches?) and be done with it! -
2 - A little setting-sun on the side of the mount, gives it a gold glow.
The ring on the back of the dish is rusty, so that begs the question, is the dish steel, too?
It shows no signs of deterioration, and is a dull gray color (in case you can't tell in the pix).
The mount has some rust peeking through the original finish.
The pipe is ... well, you can see: it was never protected from the elements.
3 - is a close-up of the above (different camera shot)
Could use a little TLC, but manageable, I think.
4 - other side of motor, showing pipe, motor, and mounting ring on the back of the dish.
Note the label. This appears to be the manufacturer.
5 - we turned the label right-side-up and it's quite readable after all these years.
Has anyone ever heard of this odd company name??
6 - note the company logo on the horn cover.
Not a particularly notable logo nor typefont.
Here, you can peek at the scalar, and a hint of how it's supported.
Looks like the LNB arms are just bent over...
7 - The rim of the dish seem to have a gentle roll-over to it.
Very hard to photograph. But here is the edge.
Note the thick metal, and round-punched holes.
Seems like it should have a molding of some sort on the edge.
8 - As for the size of the holes, I'll let you be the judge.
Pretty sure this'll run Ku just fine, though! -
Think this should be happy beside my Birdview?
It's almost a clone of the Perforated Birdviews, but I'm sure the real BV owners will object to that characterization.
After all, they do have a reputation to uphold! -
More next week, as we pull down this (hopefully) light weight aluminum (?) dish, and 63 lbs motor.
Not really afraid of this one, after the Birdview!
Stay tuned ... film at 11.
