SUCCESS!!! Using the Star Choice 75e did the trick to take care of the G18 fluctuation/interference from AMC21. I am now getting a steady signal (58-62) on 11718 and 42-46 on 11798. I would say that the dish is bumped slightly towards 121 to avoid the fluctuation and interference, since peaking on a horizontal frequency did cause a return of some mild fluctuation (45-60) on 11718, so it got bumped back till it disappeared.
Toggled between the two dishes pointed at G18, and could easily see the fluctuation on the old dish, while the 75e remained solid. I
am a very happy camper now (but what a pain it has been).
As a bonus, some of the other vertical fequencies also saw some gains (especially the 3CTV mux), but there is some loss on horizontal frequencies.
The kicker is that the LNB I am using for G18 is the one 4 degrees off centre! So the Star Choice 75e (made by Channel Master) is a great dish (and is better at getting close to (if not at) 2 degree compliancy than my Fortec Star 80cm).
Moved the G18 dish to AMC21, and am getting signals comparable (might need a slight tweak to boost the horizontals) to what I was getting on the 75e when it was pointed at AMC21.
Had to do a little bracket work to get G27 (129) as close as possible to AMC21 (125), and while I did lose a bit of signal quality due to LNB interference, I got it peaked at 60 (which is down from the 75 or so I use to get). But with its great FEC, it can drop into the low teens before I see any pixelation!
