Are My BBC'S Going Bad
bk63ross
SatelliteGuys Guru
148
San Francisco
I have been getting searching for sat signal error messages the last few days when I tune in to specific HD channels the latest DSCHD yesterday wanting to record "In The Shadow Of The Moon" but was still able to watch Monday Night Raw on USAHD. Funny thing is when I do a soft reset red button in front of HR21 everything comes back up. There are no switches involved just the direct lines from sat down to a wall plate with rated barrel connectors to receiver. Could it be the BBC'S?
Probably NOT the bbc's
Check channel 480 and 481.
You should see a confirmation at the bottom of the screen.
Jimbo
One of my BBCs crapped out recently. I found that MPEG4 stations were not coming in correctly (conveniently at the start of D*'s Free Premium Weekend) and luckily from reading all sorts of stuff on this site I knew about the MPEG2/4 differences, and I put in a Rev. C BBC that came in with my HR20 and it solved it.
Called Tech Support again last night and she said my LNB's may be going bad. We checked the Test Channels 490 and 491 and in fact I later checked 490-495 and all came in fine. They are sending me 2 replacement BBC's and will see what happens next.
The test channels you checked look at the LNB's , the ones I mentioned check the BBC's (480,481).
Jimbo
99A 103A & 103B No signal
Jimbo
I tried these and I get searching for signal 771.
We just re-tuned and got 101,110,119 hitting some good numbers.
101 94-100%
110 97-89% I worked on that one for a while and that was the best it got.
119 92-100%
we have a slim line 5 LNB dish. we just recently lost our High Def Channels.
Is the Ka/Ku LNB junk? (whatever handles the 99 & 103 Satellite)???
I thought our H21 could be the problem but when I tuned we could not get anything from 99 / 103 while everything else was fabulous! (96-100 Gee whiz! thats Great!! )
HELP!!! I'm going insane!! :eek:
101 94-100%
119 92-100%
The 99/103 is where the new mpeg4 stuff is coming from, it's a much tighter band, it will probably need to be fine tuned, particularlly if you have good signals on all the other sats, btw, your 110 signal is fine.
Have you seen the video's on how to fine tune the Slimline yet ?
It may be on the site here, but originally came from one of the sat companies (independant sales) websites.
Fine tuning will do the trick I bet, unless it is an LNB, but I think your close.
Jimbo
How many cables w/ new dish
Low 99 satellite signal = grey playback?
