Best LNBF for 10 Foot Solid Dish
chapelrun
965
14
Berryville, VA
In another thread I'm working on restoring a Channel Master 10 Foot solid Fiberglass dish. The rust was so bad on the Scalar Ring that all the bolts broke off. Thus I need a Scalar Ring and a LNBF.
I want to buy a very good LNBF that will be good for S2, 4DTV that also has a good Scalar Ring for a 10 foot dish.
What are the plus's and minus's of C-Band only or doing C-Band and KU on the same LNBF.
I have read about Norsat and CalAmp which are expense but may not be the best for S2.
If you were putting together a 10 foot solid dish - - - WHAT would you buy for the project?
Your experiences good or bad are welcome. :up
Do you want an LNBF......or do you want a servo-controlled feed?
The reason I ask is because you mention Norsat and CalAmp, and as far as I know both of them only make LNBs that would be used on a servo-controlled (or ortho) feed, not LNBFs.
Trying to keep it simple
I want a LNBF - - - sorry - - - I had read many threads and had Norsat and CalAmp on the brain.
The dish had an old Chaparral on it and I don't have any experience with servo-controlled feeds.
I have done several mini-BUD's but this will be my first big dish to get operational.
Well that narrow things way down. :)
I have never tried for Ku on my BUDs but if that is what you intend to do everything I have read on this forum leads me to recommend the Geosatpro CK1, or the DMX741 from Galaxy.
Both come with scalar rings.
I think a few have even had decent results from the BSC621, but that was the exception rather than the rule maybe.
Plus(ses): having dual-band capability on one dish?
Minuses: By most accounts it's pretty tough to get Ku to come in when you at your C-band peak, or vice versa. May require a lot of tweaking. Also they are single output, if that concerns you.
I think a guy is better off going with C-only on a BUD, and using an offset dish (like a repurposed 1.2m ex-miniBUD?) for Ku-only.
S2, you say...
...I'm working on restoring a Channel Master 10 Foot solid Fiberglass dish.
....I want to buy a very good LNBF that will be good for S2, 4DTV that also has a good Scalar Ring for a 10 foot dish.
I suggest you get in on this revival of the orthomode discussion:
Thinking about orthomode feedhorns
Everything you want to know is going to be re-discussed there.
(including good words about CalAmp and Norsat)
Only thing to add is this:
- orthomode for C-band only is not expensive.
- orthomode for C- AND Ku- bands is very expensive for the feedhorn, ... or you'll have to be seriously lucky to find one cheap.!. - :cool:
I use the BSC621 LNBF and it pegs the meter on some of the DVD-S2 8psk 30000 m/s signals. I do get some mild jerkiness on one of the channels sometimes but not the rest. I believe the receiver is underpowered instead of it being an LNBF problem.
C-Band Dish Signal Angles
Using Voom Remote for 4DTV
