BEV missing channels
Rodnee151
Cold Lake, Alberta, Canada
When I check my signal, the lowest signal strength reading I get is 96%, most are 100%, however sometimes I am missing even numbered transponders on Nimiq 82. Any ideas / suggestions that might help me troubleshoot this, please?
Cheers
Has this issue always been true since the system was installed, OR, is it a new problem that recently cropped up? What receivers do you have, what switches, what cabling, how long is the cabling. If you have more than one receiver, does the problem happen on ALL receivers, or only one, etc? We need to know what and how everything is set up to try to figure it out.
I would say it's a cabling issue of some sort. Even a pinched cable can cause issues like this. First thing I'd do is check all cable connections, and make sure they are screwed in tight. Do NOT use a wrench to over-tighten them though!
With more info about your system, we might be able to give better suggestions
As even channels are using the highest voltage (18v) it is possible that something has increased the resistance on the cable. That is normally a splitter or could be water ingress.
As you only state Nimiq 82 evens, it could also be a switch, LNBF problem.
FTA free to air satellite up or down
Dish and LNB for Shaw DSR 207 receiver
