bragging rights on 3 ft c band???
icu1954
275
lower alabama
hi,guys i have been surfing on other sites and has come across differant people bragging about getting c band on 3 ft. offset dishes with just c band lnb's...i am still new to this hobby,and from what i have learned this can't be done...is this just some kind of rip off to get you to buy c band lnb's ?
it is possible to get some of the VERY STRONG TPs if your aim is 100% correct....and you are using a good scalar ring, good LNB and have perfect focal distance.....it would not be very reliable though and you might get pixelation at times....i have had c-band reception on a 36 inch dish before....but as i said not reliable....
i cant say its out of the question and not possible....you would have to be very experienced to do this....and as i said you would only pickup a few limited and strong TPs....
I know a lot of us have tinkered with the "mini-bud" including me. Yeah I could get like 2 or 3 channels on a couple sats but that was it. Was more headache for me to spend 1/2 a day tweaking a dish to get 2 points to make the signal stable.
The 4 footers would be the minimum I would go if you do that...the 6 footers are better ;)
agreed....it is not worth the hassle....i didnt spend much time on mine....i had a ku-band motorized dish already setup and i stuck a c-band lnb on it....i was surprised when i pulled in a few channels....i was not expecting it....
It's not a ripoff, but , as has been said, that small a dish will get a couple channels, ones that you don't want to watch anyway. My motorized 1.2M dish got quite a bit of useful programming from C-band, but not nearly as much as my new 6 footer. If you want to spend money , get the cheap 6 footer from WSI, and you'll have a nice little hobby just getting it set up. :)
Now if you want to save money go out and find a used 7.5 or larger C-Band dish that has small mesh holes and you'll get a lot from one.
like the others... I could only get a couple Cband channels to lock with a 39" dish...
I would say a 6 footer is the min for Cband... it will still bring in a bunch of channels...
I did not try the 3ft, but I did do the 4ft (1.2Meter). I locked it on 91W for KU Band first then swapped the LNB out for C-Band.
It took a lot of time and a lot of tweaking using a professional sat meter (SuperBuddy 29), but I have 91W C-Band locked. CW, FMC, etc.
It's ugly since it is temporary, but it works fine.
Winter vs the FTA dish setup
New type of satellite meter on Ebay. Has anyone tried it?
