Hello Everyone,
This is my first post on your forum although I have lurked here for quite some time. This is a great site and I thank all responsible parties. Sorry in advance for the long post.
I am trying to resolve a problem with my VIP722 in my RV. As to my setup, I have a Winegard Roadtrip Digital Satellite Dome Antenna/Dish with automatic satellite seeking and alignment. Inside the RV I also have the Winegard Satellite Interface attached to the Number 1 Satellite input on the VIP722. The Number 2 Satellite input on the 722 is attached to a second coax cable from the dome on the roof. This setup has worked perfectly in the past but now it does not. The Winegard setup instructions require that after performing the check switch test you must end up with SW42 installed for both inputs in order for the receiver to function correctly. I have run this test about 30 times and have ended up with very mixed results but not the required SW42 on both inputs. Also, the number of satellites changes for no apparent reason. Sometimes I will get 3 sats on input 1 and 2 sats on input 2 OR 2 on 1and 1 on 2, etc. On my most recent attempt I tried to start from scratch and powered down the satellite interface and disconnected the coax cable to both inputs on the 722. I then unplugged the 722 and waited a minute or so, plugged it back in, ran the check switch, got the expected response (no satellites/no switch installed) on the check switch screen. I then attached the coax cables to both inputs on the 722 and powered up the satellite interface and let it run through its power up routine and locate the satellites. I then ran the check switch test and got the following result: Sat input 1 = 119 – 110 – 129 all green and SW64, Sat input 2 = 110 – 129 both green and SW42. I can't seem to figure out how to get SW42 on both inputs and how to get the correct number of satellites on each input. Any help would be greatly appreciated.
