*Choice signal strength
S
seavu
Thread Starter
Jan 30, 2005
26
I recently set up my 75e StarChoice dish [Florida, Tampa Bay] and I am wondering the correct sequence re peaking best signal strength. Locked on to satellite doing azimuth then elevation then skew...{average 70%} and would like to go higher %....is that the sequence to go for peak reception? Does skew come last in the fine tuning? or does it matter? thanks in advance.....
M
Mr Tony
299
49
Mankato, MN
skew should be the first thing
pick channel 284 or 299 and then go options 6-0-5 right arrow to diagnostic c
in the right corner is a + - number
peak using that
+5 is minimum
+7.5 is good
+10 is awesome :)
Most channels should be between +9 and +10 in that menu
S
seavu
Thread Starter
Jan 30, 2005
26
Many thanks Iceberg, as always you are a great help. Will check things out and let you know how I did...meanwhile it is Hockey Day in Canada today...so have to rush to the TV...thanks again.
M
Mr Tony
299
49
Mankato, MN
yep. Been watching it since it started
13 1/2 hours of hockey...GOTTA LOVE IT :D
S
seavu
Thread Starter
Jan 30, 2005
26
Iceberg...I have the 315 and 205 two room receiver set up. The info you gave me re signal is for the HD? On my remote under OPTIONS I... use the 6-3-1 steps for signal....I don't have the 6-0-5. Is 299 the channel to start with? Is it the weakest transponder?? my 3rd question..is the skew for the *Choice 60e dish the same as for the 75e dish at same location?? thanks again...
M
Mr Tony
299
49
Mankato, MN
yes the skew is the same for both
If the receiver is a virgin (hasn't had the signal from SC in it), you have to use 284
otherwise use 299
options 6-0-5 works...the 0 is a hidden menu :)
I have the exact same setup (315 & 205) and thats how I aim them
rkrenicki
rkrenicki
976
you may have to type the 6-0-5 slowly.. I had that issue with my receivers.. typing it too fast and missing the menus.
E
eletourneau
Dec 7, 2005
11
I answered my own question - Ignore.
Firefighter Dan
Firefighter Dan
Jan 6, 2006
27
East King County, Wash.
I have been having a heck of a time here in the NW with *C. I just purchased a 75E dish to replace my 60E that didn't have an elevation and skew bracket.
Aiming my dish using my 315, the best signal using 6-3-1 screen is 16. I checked the diagnostics (C) and it's -3.0.
I've started out at 140 degrees magnetic (I'm near Seattle), Skew is set at 80, 33 on the elevation.
Frustration part of it is, I have DishNetwork and it's a snap to tune in...
Satellite Expert
Satellite Expert
615
Your True Az is around 161 degrees.
FSS ku beams are very narrow as compared to DBS. I assume that your receiver is showing either ch 284 or 299
When you move the dish, you need to wait about 10 seconds for the reading to update. After you have got a signal, only very small moves are necessary to fine tune.
After you have acquired F1R (signal on 299); get the unit authorized. Go to ch 298 and adjust (1 at a time) AZ/EL/Skew to maximize F2 signal. Then go back to 299 to ensure that F1R is maxed.
If you have a DirecTV ellitiptical in the neighborhood, you will see correct EL and Skew. AZ for SC (111.1) is just 1.1 degree to the right of DirecTV (110.0)
Firefighter Dan
Firefighter Dan
Jan 6, 2006
27
Well that worked out great, Thanks a lot. I actually tuned my DishNet to the 110, and lined bothe dishes up. I was about 8 degrees off on my elevation. It called for 30.6 I cranked it up to 38 and it hit. I'm getting great numbers.
It's raining like hell here, and I'm shooting between cedar trees - so I'm thinking the 75E was a good way to go.
Thanks again, great common sense way aim the bugger.
