Connecting three wing dishes to Dou Node
Old Guy
10
Lawton, Michigan
The wiring diagram shows connecting three leads from a 1000.2 to a duo node without using a DPP switch. As these three are for individual satellite locations, and are not combining multiple sats on a single lead, could you attach three separate DP LNB's to the duo node without using a switch?
Actually a 1000.2 w/western arc LNB does indeed have an internal DPP switch. The Hopper nodes require DPP inputs. So... If you want to feed Hoppers then you need DPP switches ahead of the node, whether they be internal or external as rglore mentions.
If you want three separate dishes you will need either a DPP33 or a DPP44.
Sent from my iPhone 4S using Forum Runner
Dish Network needs to add WYMT. CBS Hazard, KY
Recordings list bug?
