darthsammy said:my zip is 23139, about 15 miles from antenna farm fox,abc,cbs. afew more to nbc 2 degees angle diference. and upn is sort of ld 20 degrees or so further off angle from the 1st farm. lotsa trees in my yard also. antenna guide suggest red code. thank you for any help you can give, sam
Sam ,
from what i can see from your zip code the sensor II should work just fine for you. That is if it is adjusted right beings that you are only 15 miles away it should work good the only channel i can see that you should get with it would be PBS everything else is in the same location. your antenna should be set at 109* orientation. cause all your station are there in one spot.
